Which pistons ?
10-05-2010, 09:01 PM
Which pistons ?
Thank you for the info, i think about it.
Another question: can i use high comp pistons in a bleu top ?
Historic rally, sideways is the only way !
10-05-2010, 09:07 PM
Which pistons ?
if the engine you're putting them into hasn't been decked too much there's no reason why you shouldn't be able to use them - even if everything else is stock (although a remap wouldn't hurt)
AE86 ex-daily
10-05-2010, 09:09 PM
Which pistons ?
You might bump into some problems with the different piston wrist pin diameters... Wont work unless you use a different crank.
10-05-2010, 09:21 PM
Which pistons ?
Two different explanations . . .
10-05-2010, 09:38 PM
Which pistons ?
ah well Ivan is right as I assume the piston are meant for your rods (guessing you have an old bluetop with 18mm pins you'd obviously need matching pistons) - else as Ivan said you'd be looking at the later setup (crank and rods with the bigger pins)
AE86 ex-daily
10-05-2010, 10:41 PM
Which pistons ?
Yes indeed, i need 18 mm pins.
10-05-2010, 10:47 PM
Which pistons ?
Has enyone experienced with a light weight flywheel ?
  20v BT - which oil pump? Mylesmck 4 2,785 06-21-2022 04:51 PM
Last Post: pack
  82mm Stock compression Pistons apardal 4 2,819 11-24-2021 04:26 PM
Last Post: apardal
  Rim width. Which is best.... Dino86 5 6,794 01-07-2017 03:09 PM
Last Post: Dino86
  Small Port 10.3 Pistons Alex170984 1 4,347 10-25-2016 09:18 PM
Last Post: oldeskewltoy
  which connector is this ditn 7 7,663 07-27-2015 11:24 AM
Last Post: pack
