Which pistons ?
10-05-2010, 09:01 PM
Which pistons ?
Thank you for the info, i think about it.
Another question: can i use high comp pistons in a bleu top ? Historic rally, sideways is the only way ! |
10-05-2010, 09:07 PM
Which pistons ?
if the engine you're putting them into hasn't been decked too much there's no reason why you shouldn't be able to use them - even if everything else is stock (although a remap wouldn't hurt)
AE86 ex-daily |
10-05-2010, 09:09 PM
Which pistons ?
You might bump into some problems with the different piston wrist pin diameters... Wont work unless you use a different crank.
10-05-2010, 09:21 PM
Which pistons ?
Two different explanations . . .
10-05-2010, 09:38 PM
Which pistons ?
ah well Ivan is right as I assume the piston are meant for your rods (guessing you have an old bluetop with 18mm pins you'd obviously need matching pistons) - else as Ivan said you'd be looking at the later setup (crank and rods with the bigger pins)
AE86 ex-daily |
10-05-2010, 10:41 PM
Which pistons ?
Yes indeed, i need 18 mm pins.
10-05-2010, 10:47 PM
Which pistons ?
Has enyone experienced with a light weight flywheel ?
| 20v BT - which oil pump? | Mylesmck | 4 | 4,555 |
| 82mm Stock compression Pistons | apardal | 4 | 4,281 |
| Rim width. Which is best.... | Dino86 | 5 | 8,398 |
| Small Port 10.3 Pistons | Alex170984 | 1 | 5,192 |
| which connector is this | ditn | 7 | 9,603 |
07-27-2015 11:24 AM Last Post: pack |
