Which shifter position on W series box?
01-26-2011, 08:10 AM
Just wondering which shifter position fits best on the AE86 when moving to a W55 box?
01-26-2011, 10:14 AM
Depending on your seating position and how tall you are etc.. you will want to go for the most rearward options, I think mine was the most rearward shifter you can get, but Iam a tall bugger and I had moved my seat back too. Might pay to sit in your car and just check where you would like the shifter position to be then go from there.
Shifter measurements are taken from the front of the gearbox,
(not bellhousing) back to the shifter hole.
Top row, Celica 18" 18" 19" and 20.5"
Bottom row Supra, 18" 18" 19" 20.5" 20.5" and 21"
Right is a remote shifter puts the leaver about 20cm off the gearbox end.
[Image: AEU86 AE86 - Which shifter position on W series box?]
More info here:
http://www.retrotech.co.nz/Tech/Toyota-boxes.php
Corolla Levin SR 1984 AE-85 (Project car)
Corolla Runx Z 2002 (Runabout)
01-27-2011, 12:17 PM
Depends on if you want it to come out of the stock hole with no modifications. If you have a 4ag there are two options, depending on how your mounting the w5x to the engine. If using
Adapter plate: 18"
Bellhousing: 19"
Stock T-50 position is 19.25"
Andrew
  TRD Short Shifter Rattle Noise, It's Normal? Mattolo 19 24,316 04-27-2024 10:04 PM
  Clicking noise from glove box chrisae86 4 3,703 09-08-2022 11:36 PM
Last Post: chrisae86
  20v BT - which oil pump? Mylesmck 4 4,537 06-21-2022 04:51 PM
Last Post: pack
  Rim width. Which is best.... Dino86 5 8,374 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 9,546 07-27-2015 11:24 AM
Last Post: pack
