Wich camshaft.. everlasting question !?
04-11-2007, 05:59 PM
4AGE bluetop.
Autronic SM4 SAECU, Higher compression 11:1...
Stock intake without T-VIS, possible stock intake with larger butterfly (7MGE 60 mm) or ITB (AE101).
The goal is not power peak, must is constant power trough certain RPM band, and no more than 8500 rpm peak. And the car must be possible to drive daily (with some compromise Smile )
And 160 HP at crank is must .. Smile
What camshaft and valve setup to put in !? To go for oversize valves (1-2 mm) or not ? What degree and lift cams ? Any recomandations or even expirience would be better .. Wave
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
04-11-2007, 07:19 PM
I´m a bit suspicious to talk about this because i am a TODA fan. If your goal is 160 hp, I would sugest something arround 264º. There are a lot of brands making kams for the 4age (kent cams produce them too), but, as I stated before i´m a Toda fan, so i recomend them.
Toda is known not by the peak power but making power through a large rpm band. HKS is good too, but a bit more high ended.
A good engine diagram, worked head, valve springs... etc should do it. I saw you're using a stand alone ecu, should be easier.
Have you seen Bill Sherwood's page?
http://www.billzilla.org/4agmods.htm#150hp
[Image: AEU86 AE86 - Wich camshaft.. everlasting question !?]
Cump´s
Filipe Oliveira
04-11-2007, 07:33 PM
I will try 272/8.1 lift or similar cams + ITB and good header.
You can go even over 11CR with big cams.
04-12-2007, 12:38 AM
With Autronic SAECU the options are endless... the lift can be more than 8,5 (what stock ECU "can" handle), and oversized valves are no problem..
But what concrete cams setup shoud give wanted results.. that we don't do overkill with to agressive cams.. Evil
Any difference for choice of cams for stock intake and AE101 ITB's ?
04-12-2007, 12:49 AM
For 160 hp I would say a couple of 272º 8.1 lift (HKS for example).
Stock intake manifold, stock ECU if you can change the rev limit. Plus exhaust and a nice compression ratio, and a little head work and you should be fine! To compensate the lack (or excess) of gas, use a piggy back system to make things simple.
Best regards
04-12-2007, 01:45 AM
Quote:To compensate the lack (or excess) of gas, use a piggy back system to make things simple.
Now that you mention it. Anyone tried piggy backs systems? Even in a stock engine? How was it running?
Cump´s
Filipe Oliveira
04-12-2007, 10:06 AM
I have an Apexi SAFC although I havn't used it yet. Might come handy.
Many people have used it and it works.
Best regards
04-12-2007, 10:27 AM
272 degree without complete exhaust etc is impossible. The torgue you need requires lift. Lift requires valve mod. So its a bit harde then you think,
160hp is possible but you either do a few mods and you might reach 160 at the crank or you go full mods and then you might as well hit 170-190 hp
04-12-2007, 01:15 PM
robokill Wrote:160hp is possible but you either do a few mods and you might reach 160 at the crank or you go full mods and then you might as well hit 170-190 hp
What cams to hit 160 HP with out any doubt, and maybe 170-180 HP (and still be able to drive the car normal on the road) ?
A see everybody recommend 272 degrees, but ~8 mm lift sems to low (for 160-170 HP)... to go for 9-10 mm lift. Would it damage the engine and become useless for normal driveing (high idle, absolutely no tourqe at low rpm)
Higher compression, Standalone ECU, full open and calculated exhaust, open intake, valve job, head job we got.
Now is the question what cams to put in and to go for ITB or leave stock intake ... Smile
04-12-2007, 01:19 PM
Meshin, I recommended 8.1 lift because with more lift you must use underbucket valve shims ($$$).
  Question about camshaft CHACAMAN 2 4,643 07-07-2020 06:41 PM
  Camshaft ID kazi 6 9,166 09-26-2018 12:07 AM
  Anyone farmiliar with hks camshaft types for 4age? spill86 5 18,919 11-18-2017 11:36 PM
  Camshaft sprocket bolt size? harkes 1 5,645 07-03-2015 12:41 PM
Last Post: Dave W
  Camshaft questions d3nso 7 9,483 08-16-2013 11:19 PM
Last Post: jondee86
