Wilwood Brake Kits €600 each
09-19-2012, 09:47 AM
275mm and 260mm brake kits to suit 13" - 15" wheels
Kit consists of 2 off Wilwood Dynalite calipers 2 off Drilled and vented discs (grooved only discs €30 extra) All mounting brackets and fitting kit Brake pads Braided stainless steel hose kit Tech: 257 x 23mm disc for use with 13" wheels approx 300mm clearance required 275 x 25mm disc for use with 15" and some 14" wheels approx 320mm clearance required 275mm kit may require slight trimming of the lower control arm depending on LCA and roll centre Replacement parts Discs: €50 per side Pads: Wilwood (as per kit) €40, Mintex M1144 €100, Ferodo DS 2500, €150 Fitted: Price €600 per kit Delivery to uk €18, rest of eu approx €30 |
09-19-2012, 10:35 AM
Brackets are for which cars?
danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
09-19-2012, 11:14 AM
for ae86
09-19-2012, 01:25 PM
Cool. It would be nice if you fill it in the title of the article. :wink:
10-22-2012, 11:00 AM
Hello ep71,
This kit (257 x 23mm disc for use with 13" wheels) can fit into a classic ´76 Celica TA23??.... would be interested. I think the "AE86 and TA23" suspension are similar. Thanks. |
10-23-2012, 03:03 AM
Hi, I am pretty sure the ta22 strut is different so you would need to switch to using ae86 struts and hubs
10-23-2012, 10:18 AM
ep71 Wrote:Hi, I am pretty sure the ta22 strut is different so you would need to switch to using ae86 struts and hubs ep71 thanks reply, To avoid me changing the struts and hubs, would be possible to make this kit to Celica TA22/TA23 ?? thanks again |
10-24-2012, 12:22 AM
not really, it would require a complete redesign of the mounting brackets. if you wish i could supply just the discs, calipers, lines and pads and you could make up your own mounting brackets
10-24-2012, 03:58 AM
Could you supply calipers, lines, pads, and 257 discs for 4x100 hubs?
Price? Japan 4 Ever |
10-24-2012, 01:05 PM
ep71 Wrote:not really, it would require a complete redesign of the mounting brackets. if you wish i could supply just the discs, calipers, lines and pads and you could make up your own mounting brackets Probably "as you say" the best option would be to get the struts and hubs of AE86 for mount them on my celica TA23. Now the problem would be get the parts of the AE86...... Thank you very much for your explanations. If I get the AE86 parts with good price , I will contact you again. regards. |
Group A --- Body Kits Jblood, Vertex, RunFree, Goodline | Group A | 20 | 39,079 |
03-20-2013 10:01 PM Last Post: alimonos |
Track and road brake kits | ep71 | 12 | 15,457 |
09-17-2012 10:28 AM Last Post: ep71 |
P.A.S.S - D-Max, Runfree, Vertex, CBY, Goodline, Jblood KITS | SYM | 41 | 57,075 |
07-31-2009 11:20 AM Last Post: SYM |
MAXGRIP 7.5" Supra LSD kits | WeirPerformance | 1 | 3,694 |
03-17-2009 07:41 AM Last Post: WeirPerformance |
