Your Digital Clock
07-31-2006, 02:54 PM
Your Digital Clock
mine's not working
Philip
07-31-2006, 03:57 PM
Your Digital Clock
Mine works too.
You don't need the set button to be pressed in order to adjust the time. I've done it a few times after disconnecting the battery...
07-31-2006, 04:07 PM
Your Digital Clock
Well mine needs it..
07-31-2006, 04:10 PM
Your Digital Clock
Mine is a USDM version. Everything can be different for the US... Smile
08-03-2006, 08:55 PM
Your Digital Clock
Ivan141 Wrote:It is the set button. You need to keep it pressed in when you want to adjust the time.
No it's not! It is the set button yes, but you don't have to push it to adjust the time...
My drivers manual reveals it's meant for synchronizing your clock with the beep some radio stations broadcast every hour. If you press it the clock jumps to the nearest hour. (so press it at 13:57 and it jumps to 14:00, press it at 14:02 and it goes to 14:00 as well)
08-03-2006, 10:41 PM
Your Digital Clock
Hamsupjai are you talking about the digital speedo?
08-04-2006, 08:09 AM
Your Digital Clock
I beg to disagree, mine does not jump to the nearest hour, it just "unlocks" the other two buttons for use.. think they just use some kind of &gate in there.
08-04-2006, 12:32 PM
Your Digital Clock
Then there's probably an older and a newer type clock and they didn't know what to do with the set button in the newer type so they thought of this radio synchronizing button... If I had a scanner here I'd show you the text from my drivers manual, and it really does work that way in my car.
08-06-2006, 01:15 PM
Your Digital Clock
Mine works and does need the set button. Smile
(BTW: probably still the original USDM version)
[Image: AEU86 AE86 - Your Digital Clock]
08-08-2006, 05:07 PM
Your Digital Clock
works perfectly Thumbs up!
TUNING IS NOT A CRIME
Photo How to add photos to your posts banpei 2 5,970 01-17-2022 10:31 PM
  what is your opinions on these head gaskets... CHOPKIN2 5 5,994 04-09-2018 05:29 PM
  KE70 - need your help! zemosh 2 5,653 03-19-2015 07:42 PM
Last Post: willy
  Need your help,looking for a rallcar thats looks like this ditn 17 21,226 04-11-2013 07:13 PM
Last Post: ditn
  Camshafts... what is your desire? oldeskewltoy 9 9,102 03-23-2013 02:41 PM
Last Post: Uzelac
