Your Digital Clock
07-31-2006, 02:54 PM
Your Digital Clock
mine's not working
Philip |
07-31-2006, 03:57 PM
Your Digital Clock
Mine works too.
You don't need the set button to be pressed in order to adjust the time. I've done it a few times after disconnecting the battery... |
07-31-2006, 04:07 PM
Your Digital Clock
Well mine needs it..
07-31-2006, 04:10 PM
Your Digital Clock
Mine is a USDM version. Everything can be different for the US...
08-03-2006, 08:55 PM
Your Digital Clock
Ivan141 Wrote:It is the set button. You need to keep it pressed in when you want to adjust the time. No it's not! It is the set button yes, but you don't have to push it to adjust the time... My drivers manual reveals it's meant for synchronizing your clock with the beep some radio stations broadcast every hour. If you press it the clock jumps to the nearest hour. (so press it at 13:57 and it jumps to 14:00, press it at 14:02 and it goes to 14:00 as well) |
08-03-2006, 10:41 PM
Your Digital Clock
Hamsupjai are you talking about the digital speedo?
08-04-2006, 08:09 AM
Your Digital Clock
EE80Liftback Wrote:Ivan141 Wrote:It is the set button. You need to keep it pressed in when you want to adjust the time. I beg to disagree, mine does not jump to the nearest hour, it just "unlocks" the other two buttons for use.. think they just use some kind of &gate in there. FABRICA MI DIEM, PVNC! |
08-04-2006, 12:32 PM
Your Digital Clock
Then there's probably an older and a newer type clock and they didn't know what to do with the set button in the newer type so they thought of this radio synchronizing button... If I had a scanner here I'd show you the text from my drivers manual, and it really does work that way in my car.
08-06-2006, 01:15 PM
Your Digital Clock
Mine works and does need the set button.
(BTW: probably still the original USDM version) 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
08-08-2006, 05:07 PM
Your Digital Clock
works perfectly
TUNING IS NOT A CRIME |
How to add photos to your posts | banpei | 2 | 5,969 |
01-17-2022 10:31 PM Last Post: banpei |
what is your opinions on these head gaskets... | CHOPKIN2 | 5 | 5,993 |
04-09-2018 05:29 PM Last Post: mad.matt |
KE70 - need your help! | zemosh | 2 | 5,652 |
03-19-2015 07:42 PM Last Post: willy |
Need your help,looking for a rallcar thats looks like this | ditn | 17 | 21,226 |
04-11-2013 07:13 PM Last Post: ditn |
Camshafts... what is your desire? | oldeskewltoy | 9 | 9,102 |
03-23-2013 02:41 PM Last Post: Uzelac |
