ae86 crush sleeve length
02-18-2014, 06:55 PM
Hi. Does anyone know the length of a new and unused crush sleeve or pinion spacer for the pinion gear. Also, the solid spacer pinion has the same length of the crush sleeve? Many thanks
02-18-2014, 10:53 PM
![]() http://forums.club4ag.com/zerothread?id=31174 Crush tube is compressed (crushed) on purpose until the required preload on the bearings is achieved. It does not use shims. Solid spacer does not crush. Shims are added or subtracted and the assembly torqued up to achieve the required preload. The process mey have to be repeated several times until the preload is correct. The two items cannot be compared by length. Cheers... jondee86 |
02-19-2014, 01:59 AM
Thanks jondee. Yep I understand, I just want to know if I can still use my old crush sleeve. Getting a new crush sleeve is hard to find in my area, and if I order solid spacer, it will take time to get here. I'm planning to make a solid spacer and shims if my old sleeve needs to be replaced and I can't find a new one here.
02-19-2014, 06:01 AM
The OEM crush sleeve is designed as a one time use item. The factory
say you should use a new one each time. However, if you understand the purpose of the crush sleeve, then it is possible to re-use it under certain circumstances. For example, there was a very good writeup somewhere on the old Club4AG site, showing how to change a leaking pinion seal without using a new crush tube. In that case the bearings are not changed and so the distance apart does not change. By tightening the nut back to exactly the place it was before, the original preload is again obtained. But when the bearings are changed, it is likely that the bearings will be slightly further apart, and therefore the bearings will contact the outer race and become preloaded before the crush sleeve is loaded. ![]() This will result in the crush tube being loose on the shaft, and the shaft being able to float longitudinally, changing the contact patch between the CW and pinion. Therefore when fitting new bearings you should always use a new crush tube. The purpose of the crush tube is to act as a self- adjusting (no shims) spacer between the inner bearing races. A solid spacer needs to be shimmed to obtain correct preload, and that can be a time consuming process. Cheers... jondee86 PS: You could of course try using a shim with the old crush tube to get a second life out of it, but for sure I never told you that ![]() |
02-19-2014, 11:30 AM
thanks again jondee. Now I am stuck on what to do. I tried looking for a new one and can't find new crush sleeve. If only I know the dimensions of the solid space, I can temporarily fabricate one till I get a new solid spacer. I already set the pinion and carrier bearing preload, and also backlash. Should I install it or not? Btw, the R and P are new 4.778 from weir
02-19-2014, 12:14 PM
Total length of the solid spacer is 54.5mm, if that can help.
02-19-2014, 01:04 PM
How is that crush tube so hard to find? Toyota sell a kit for the differential that contains it for a reasonable price IIRC. I think I have 2 of them somewhere in my basement. If you really cant get it locally I would consider selling one to you, but that will take time as well.
02-19-2014, 02:04 PM
choyr Wrote:I already set the pinion and carrier bearing preload, andYou can't use the differential assembly without a spacer or crush tube. If you do, you risk serious damage to the CW&P and the pinion bearings. The spacer or crush tube is there to lock the two bearings solidly together with the specified torque applied to the pinion nut. You cannot torque the nut and lock the shaft in position without a spacer or crush tube. Cheers... jondee86 |
02-19-2014, 03:55 PM
jondee, currently the spacer installed is the old one. it is already in rotating torque of around 11inlb.
@ivan, i'm living in the mountains ![]() ![]() @thanks project D. I will try to tell this to my friend, also rely the thickness (3mm) from this blog. http://tkamango.blogspot.com/2012/01/sol...eeves.html I will also bring my old pinion gear as basis for the solid spacer. I will also make him fabricate shims with different thickness. will try it tomorrow morning. Is mild steel enough or I should use carbon steel? many thanks everyone |
02-19-2014, 11:20 PM
choyr Wrote:... currently the spacer installed is the old one. it is alreadyHow much torque was applied to the pinion nut to reach the 11inlb of rotating torque ? If you applied 80ft-lb or more to the nut before reaching the 11inlb, then the crush sleeve is supporting the bearings correctly, and you should be able to use the pinion. But if you reached 11inlb with only 20 or 30ft-lb of torque on the nut, then there is not sufficient load on the sleeve, and you should not use it. Cheers... jondee86 |
Rear arm length | totta Crolla | 7 | 1,307 |
06-05-2024 08:53 AM Last Post: totta Crolla |
4AGE 20v Ignition Lead Length | mad.matt | 3 | 6,773 |
10-01-2014 03:43 PM Last Post: mad.matt |
Door length | Ivan141 | 3 | 5,064 |
03-18-2014 02:11 PM Last Post: Ivan141 |
Length of factory cat | Rick | 4 | 7,800 |
08-07-2013 06:03 AM Last Post: jondee86 |
Valve springs length | Vil | 4 | 5,948 |
04-04-2013 07:41 PM Last Post: oldeskewltoy |
