06-26-2013, 11:15 PM
Post: #91
corolla4agze Wrote:i have read that is200 engine mounts are similar but harder.. those not cost lot.By doing this you just lost 8mm of lowering the car . these effect the geometry. i dont agry by using spacers . 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
06-27-2013, 12:01 AM
Post: #92
i do have 35mm RCA on front =) so still on big plus.
those spacers help lot on roon in tunnel, and whit turbo the hood is quite close also. STILL the engines oil pan dount SIT SO LOW.. it sit lower than front axle if you put it rest to axle and no spacers. Now i not need put it laying so low. |
06-27-2013, 01:17 AM
Post: #93
corolla4agze Wrote:i do have 35mm RCA on front =) so still on big plus.i have 45mm rca .if you need to go low you dont want spacers 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
06-27-2013, 12:45 PM
Post: #94
i would be a bit worried about you new alloy harmonic balancer as this will break your crank on the front
also if you go dry sump i have dry sump pans in stock to suit all 3sge motors in fwd or rwd |
06-27-2013, 05:11 PM
Post: #95
Celica RA45 Wrote:i would be a bit worried about you new alloy harmonic balancer as this will break your crank on the frontyes i will need a dry sump later when i will tune up the engine pistons cams etc. Thanks. can you explain the meaning of this?{ i would be a bit worried about you new alloy harmonic balancer as this will break your crank on the front} Alloy harmonic balancer ???? why brake the crank ??? Sorry make it more simple my english are not so good . Thanks 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
06-27-2013, 06:28 PM
Post: #96
What brand outer tie rods are you using (the purple ones) and how do you like them?
06-27-2013, 11:44 PM
Post: #97
Deuce Cam Wrote:What brand outer tie rods are you using (the purple ones) and how do you like them?Nagisa auto. Exelent 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
06-28-2013, 05:05 AM
Post: #98
std harmonic balancer has rubber built into it to take harsh harmonics out of crank
yours is just a lightweight peice of alloy with no crank dampening built into it |
06-28-2013, 10:32 AM
Post: #99
Celica RA45 Wrote:std harmonic balancer has rubber built into it to take harsh harmonics out of crankIf you mean the crank shaft pulley the std. was without rubber just a heavy steal one they also sell one alloy here it is http://www.fortyone.co.nz/parts/view/14023.html . i just make one by my self . other then this i dint change somthing else . 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
06-28-2013, 11:25 AM
Post: #100
Great project, keep up the good work
I'm currently taking HRT ~ Hachi Roku Therapy |
Racecar: TRD USA built ITA AE86 | oldeskewltoy | 38 | 42,142 |
07-22-2019 02:55 PM Last Post: apardal |
Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 87,720 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 726,005 |
AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 603,479 |
S.K.s AE86 racecar | S.K. | 207 | 220,168 |
09-18-2016 11:39 AM Last Post: totta Crolla |
