aeroquip push on hose & fittings
07-16-2008, 05:16 PM
Anyone any problems putting steel fittings on aeroquip push on hose?
Have got ones to fit oil cooler to my ae86. Having problems, tried oiling and lubricating fittings but can't get them to push on fully! Hands are getting sore!
Any special way of doing it, screw it/ push straight?
Any help appreciated, read a few people on here have used these before.
[Image: AEU86 AE86 - aeroquip push on hose & fittings]
Listen to the whine.
Not just a carbon copy.
07-16-2008, 09:24 PM
Those are a bitch to fit, try heating them up before inserting.
07-17-2008, 01:32 AM
With hose fittings what I have noticed is that you need to make sure that the barb sits nice and even.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
07-17-2008, 03:58 AM
I lubricated the fitting and hose with oil, and warmed up the hose carefully with a heat gun. Put the fitting in a vice with soft jaws and then pushed like *&^%#@.
Make sure you dont accidently melt the plastic ring on the fitting if you heat that too.
07-17-2008, 11:30 AM
cheers, getting there now, suspose the harder to get on the less chance to blow off
  fuel line hose from the pump Wikizz 4 6,264 10-16-2017 07:11 PM
Last Post: jdm86gtz
  cool lower radiator hose thanos 4 5,745 11-29-2016 01:06 PM
Last Post: thanos
  How far should I have to push my clutch in dinkers542 4 6,410 11-29-2014 11:18 PM
Last Post: dinkers542
  Swedged or crimped hose ends? drako323 6 6,595 02-10-2010 03:03 PM
Last Post: boo50
  Help me add some hose power to my ae86! jeenyus 3 4,307 12-04-2008 03:14 AM
Last Post: Chrisso
