and im off AE86 trueno, Silvertop project, but wait SR5?
10-25-2006, 06:41 AM
Post: #31
Just and update, with pics this time...
and for Nohachi, I've dones this in my "four day weekend" |
10-25-2006, 09:19 AM
Post: #32
Ah looks like you're on your way to get her running
Any ideas yet when you'll be starting on the swap or have you desided to let that rest for awhile? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-25-2006, 03:57 PM
Post: #33
Well, after I looked at the vems loom I am thinkning that I am going to go with that, its about 300 dollars, and I can get a silvertop loom for 200, but with the vems loom I dont have to cut into the firewall for the distrubiter, which just makes life that much easier. So first I will have to come up with some money, then I will be able to continue with the swap.
10-25-2006, 04:48 PM
Post: #34
Its just 300 for the loom right? Not including the VEMS unit itself...Count on around 1000$ to 1200$ for a complete VEMS setup. Support for the VEMS seems to better in Europe then the US. Consider a MegaSquirt..its less powerfull, but better supported at your end of the pond and a bit cheaper.
11-07-2006, 07:11 AM
Post: #35
Yeah, your right noHachi *meh* oh well that'll be a later project,
But She runs, and back on the road! |
01-03-2007, 07:36 AM
Post: #36
Well it definatly has been a long time since I have posted anything.
but a few things have changed. I have set up a stereo in my car now, Sony Xplod. As well as I finally got enough money to get a megasquirt system. As soon as I buy it and put it together, test it, all that good stuff Im pulling my 86 in to do an engine swap. |
01-25-2007, 09:18 AM
Post: #37
Alright, I am looking for a fuel pump, would this one work?
http://www.treperformance.com/FuelPumps/...Pumps.html its like $70 so its not too bad. |
01-26-2007, 08:26 AM
Post: #38
Is anyone going to answer??? or have you all figured this thread dead?
01-26-2007, 10:06 AM
Post: #39
Nah, I think people are just busy atm, its middle of the week you know
I have no idea if this is a good fuel pump. Doesn't really list the GT so you may need to do some alterations, then again, having an SR5 fuel tank you prolly need to do that anyways Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
01-26-2007, 10:34 AM
Post: #40
255hp fuelpump might overpower the stock regulator..that would give you to high fuel pressure..I'm not 100% sure, so its worth researching..
Scuderia rollator CE86 trueno project | NoHachi | 136 | 155,124 |
04-15-2013 05:53 PM Last Post: [Walaki]D`Lair |
my slow trueno project | cfly86 | 38 | 42,642 |
12-12-2012 04:35 AM Last Post: cfly86 |
My Drift project - 83' Trueno coupe | doggy | 158 | 271,745 |
10-23-2012 10:58 AM Last Post: Lightning |
1986 Corolla SR5 S2k Build.... MIami style | geoscranny84 | 16 | 22,316 |
04-26-2012 08:00 PM Last Post: [Walaki]D`Lair |
1987 sr5 project | purplerain11 | 3 | 6,234 |
04-15-2012 03:34 AM Last Post: purplerain11 |
