another AE86 around here
01-14-2007, 08:52 PM
84' AE86 Levin 96' 500HP WRX, powered by landikar |
01-15-2007, 11:08 PM
some videos captured with GSM
http://www.vbox7.com/play:ffcc7d1f http://www.vbox7.com/play:28d9fa2c good shots from drift event My bro in impreza and my friend in my AE86 84' AE86 Levin 96' 500HP WRX, powered by landikar |
01-16-2007, 02:42 AM
video - that day fully stock Hachi performed the longest drift
http://www.vbox7.com/play:83f0c667 84' AE86 Levin 96' 500HP WRX, powered by landikar |
01-16-2007, 11:27 PM
10-23-2007, 12:41 AM
hi again
last upgrade was about cooling system - TRD radiator cap 1.3 bar and racing alluminium radiator from S13. and of cource good exhaust system - 50mm with high frequency setup. now i have good power in 4500-7500rpm range with stock engine video stuff from last event on Drakon race track, driving my good friend ghost rider. the tires are 195/45/14, KOYO front and DUNLOP rear - drifting on 3rd gear http://www.youtube.com/watch?v=N5_hR7C1eGs im working on some suspention upgrades, soon will be fitted: swift 6/4.5 tanabe sways 25/20 T3 camber plates T3 RCA traction brackets cusco clutch kit i have to upgrade the PCV system - known problem on long left turns and oil leak into the manifold. i switched the valve covers - with no result. sure i'll fix it after that i will use only Motul 300V 10w40 racing oil with TRD oil filter see you soon 84' AE86 Levin 96' 500HP WRX, powered by landikar |
12-18-2007, 01:26 AM
hi folks
hachi racing suspension is ready Tanabe racing sways, Swift racing springs, T3 rca and traction brackets, T3 camber plates, racing steel flywheel JDM 3.7kg, T3 light weight crank pulley 600g, new clutch brakes rebuild gearbox oil changed to MOTUL racing brakes fluid changed to MOTUL racing TRD racing oil filter im waiting for racing disk and pads and cusco racing clutch kit. and maybe headers, HKS 264 cams and cam pulleys - will run it on stock ECU new look - low profile: ...and action look last drift event - that day on Drakon hachi ran about 150km on the track - with no ANY problems, engine revs up to 7500rpm as usual to the limiter, with very good power band. I set up car for winter conditions - toe out - zero camber - one degree negative caster - 3.5 degrees for good track conditions i will use more agressive setup. video stuff - driving my good friend Alex - he is the champion this year, class 1600cc Italian pursuit on Drakon race track. next year i will race hachi on this championship. low quality video, a lot of fun with this crazy car - AE86! http://www.youtube.com/watch?v=5PxQGLOE7tg 84' AE86 Levin 96' 500HP WRX, powered by landikar |
12-18-2007, 01:59 AM
can i ask about this cooler what brand it is and where you buyed it? my cooler is almost dead.
http://www.86ers.org All the hachies that Daytona can only dream about. |
12-18-2007, 07:24 AM
Nice Drift
12-20-2007, 09:12 PM
the racing radiator is something from china the model is for nissan S13, but is is very easy to fit it to corolla with minor changes.
im working at Subaru Performance Center, we deal with racing and high tuned sport cars - so I compared this china radiator to original Blitz and Koyo racing - it is good one. so I decided to save some money now my temp. gauge is always below the half of the scale, and engine has strong run all the time 84' AE86 Levin 96' 500HP WRX, powered by landikar |
12-24-2007, 05:46 PM
http://video.google.com/videoplay?docid=...6672801640
season closing - wet wet wet drift drift drift 84' AE86 Levin 96' 500HP WRX, powered by landikar |
Another AE86, Duracell. Now with VEMS, and cage... | Uzelac | 62 | 87,921 |
06-22-2015 02:56 PM Last Post: Uzelac |
OST-029: California here I come..... | oldeskewltoy | 26 | 27,328 |
03-12-2015 06:39 PM Last Post: oldeskewltoy |
project "twin cam 16" another AE86... | fax0815 | 11 | 17,900 |
11-19-2011 09:05 AM Last Post: BOOMEX |
ANOTHER Australian AE86 | delazy | 25 | 37,889 |
10-17-2010 10:54 AM Last Post: worholm |
Chiro- another Croatian AE86 | mrgud | 154 | 144,636 |
10-12-2009 05:46 PM Last Post: einneb |
