bouncing idle ?!
11-24-2007, 12:20 PM
bouncing idle ?!
YEAH GOT IT!!! NO BOUNCING ANYMORE!
it was the coolant! no water in the radiator! THANK YOU ALL!!! i got 1000rpm @ warm engine! is that to high? ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., http://www.sideways.co.at ,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-.,.-., |
11-24-2007, 12:38 PM
bouncing idle ?!
I think the perfect idle is ~850 RPM but 1000 is acceptable, esp. winter :wink:
11-24-2007, 02:19 PM
bouncing idle ?!
Mine idles at 900~1000 rpm normaly, sometimes at 800rpm, but i´ve experienced some minor rpm meter faultys. In 5th gear at 90kms/h sometimes it goes at 3000rpm, other times at 3100rpm. The engine sounds good, revs good, never experienced anithing bad at the time, so i give it a break...
Idle at 1000 rpm shouldnt be a problem... Cump´s Filipe Oliveira |
11-24-2007, 07:31 PM
bouncing idle ?!
Mine depended on the season. During summer the car idled between 800 and 850 and during winter between 1000 and 1200. So don't worry about a bit higher idle
11-25-2007, 02:09 AM
bouncing idle ?!
Soooooooo.... WHY do these engines get a loping idle when the
coolant is low ?? It must be an ECU controlled thing, as a simple waxstat does not have a fast enough response time to cause loping Lack of coolant just means the waxstat does not heat up as quickly, and all this will do is cause is the idle to stay high for longer. Any theories ?? Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,487 |
Engine starts/revs but no idle | GenkiMotors | 17 | 7,449 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
exhaust odor/idle MOT issue | Ryo | 7 | 7,325 |
20v silvertop idle issue | AlexFourTwenty | 3 | 5,196 |
12-24-2017 03:27 AM Last Post: AlexFourTwenty |
Silver top low idle | AlexFourTwenty | 7 | 10,222 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
User(s) browsing this thread: 12 Guest(s)
