bouncing idle ?!
11-24-2007, 12:20 PM
bouncing idle ?!
YEAH GOT IT!!! NO BOUNCING ANYMORE! Wink
it was the coolant! no water in the radiator!
THANK YOU ALL!!! Hurray! Hurray! Hurray!
i got 1000rpm @ warm engine! is that to high?
http://www.sideways.co.at
11-24-2007, 12:38 PM
bouncing idle ?!
I think the perfect idle is ~850 RPM but 1000 is acceptable, esp. winter :wink:
11-24-2007, 02:19 PM
bouncing idle ?!
Mine idles at 900~1000 rpm normaly, sometimes at 800rpm, but i´ve experienced some minor rpm meter faultys. In 5th gear at 90kms/h sometimes it goes at 3000rpm, other times at 3100rpm. The engine sounds good, revs good, never experienced anithing bad at the time, so i give it a break...
Idle at 1000 rpm shouldnt be a problem...
[Image: AEU86 AE86 - bouncing idle ?!]
Cump´s
Filipe Oliveira
11-24-2007, 07:31 PM
bouncing idle ?!
Mine depended on the season. During summer the car idled between 800 and 850 and during winter between 1000 and 1200. So don't worry about a bit higher idle Wink
11-25-2007, 02:09 AM
bouncing idle ?!
Soooooooo.... WHY do these engines get a loping idle when the
coolant is low ?? It must be an ECU controlled thing, as a simple waxstat
does not have a fast enough response time to cause loping Confused
Lack of coolant just means the waxstat does not heat up as quickly, and
all this will do is cause is the idle to stay high for longer.
Any theories ??
Cheers... jondee86
  No idle below 2000 rpm rich running Steller Engineering 3 1,484 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine starts/revs but no idle GenkiMotors 17 7,447 11-20-2021 04:12 AM
Last Post: GenkiMotors
  exhaust odor/idle MOT issue Ryo 7 7,325 07-15-2019 09:17 AM
Last Post: jondee86
  20v silvertop idle issue AlexFourTwenty 3 5,195 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  Silver top low idle AlexFourTwenty 7 10,221 10-16-2017 10:22 PM
