cannabolics hachi...
06-11-2009, 05:38 PM
Are you sure this is the way you want to go with the repair? That's a lot of welding! You could bend up some sides and weld a plate on top of that.
06-11-2009, 11:31 PM
Thanks for the tip Ivan Thumbs up!
Yeah, it's a lot of welding and I also didn't think of the accessibility. Due to the spare wheel compartment it is hard to get a decent welding position so change the concept.
Someone else also mentioned the way you, Ivan are talking about but I'll just bend one side and only half ways. It's 2 mm gauge steel and it's difficult to work with without the proper equipment.
[Image: AEU86 AE86 - cannabolics hachi...]
Hope that it'll be fine
Philip
06-13-2009, 08:17 PM
I finished with the rear profile. It could have been better (meaning like Ivan said = less welding), but hopefully it'll work.
A also started the fixing the spring nest. First I painted everything with weld 2 primer. This stuff is great Thumbs up!
...then welding it in
Next up is the rear strut support.
Philip
06-14-2009, 12:43 PM
Pics dont work for me Dumb question
06-14-2009, 05:35 PM
Ivan141 Wrote:Pics dont work for me Dumb question
When I am updating I don't see the latest pics too. Dunno what the problem is. I use Picasa Web Album.
Here's a new update.
Rear strut support. cleaned, phosphorized, primed and spot welded in.
This is how it looks from inside
the other side.
I gonna cut little of the new part and add a small piece left from the original strut support. then strengthen it with solid plate.
Philip
06-14-2009, 06:33 PM
Does everybody have troubles seeing some pics??
Dunno what's happening...
Philip
06-14-2009, 07:06 PM
I can see some pics now.. Looks okay to me for an undercar repair.
You have your work cut out for you with the inner wheel wells though.
06-15-2009, 07:31 PM
Well just like Ivan said
I have to admit that I was a little bit to eager for cutting with the angle grinder. Should never had done it that way. I managed to form the inner wheel well and place the strut support. It was a lot of measuring Huh like every hit/weld. I also took the references of two other rollas just to be sure.
Will add some more plate to strengthen it up, some welds and the strut "collar".
Jeeyo Cool
Philip
06-16-2009, 09:34 PM
...some progress
added some welds
from inside
cleaned and primer'd
...the plate too
...i think it looks much better
Philip
06-17-2009, 10:13 PM
Very nice work! Much respect for your plateforming skills.
