car wont start, could it be what?
02-24-2010, 11:03 AM
Hello,
My car was running fine until i shut it off. and tried to start it. it wont start. the starter crank very very slow, like its not having enough power and all the light dims. i thought its was the alternator, so i got a new alternator. the car is still doing the same thing. so i bought a new battery. and the car is still doing the same thing. and finally i bought a new starter and its doing the same thing..now i don't know what the problem is. my guess maybe i have a bad grounding to the engine or something. the start is trying its hardest to crank. maybe i have a crack on the flywheel teeth to the start..
02-24-2010, 11:59 AM
Did you try running a + cable directly to the starter? If it starts then you know that you have a short somewhere in the system.
02-24-2010, 12:17 PM
What noHachi said.
Check all ground wiring going to the engine.
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
[Image: AEU86 AE86 - car wont start, could it be what?]
02-24-2010, 03:14 PM
also check the plug (and wires) from your alternator, i had a similar problem a few years ago in my red hachi, my starter did the same as yours . all wires are circuted, because of the years the cable isolation wasn´t good any more, i had luck that it doesnt start to burn.....
greets
02-25-2010, 04:55 AM
braq Wrote:Hello,
dude omg u spent alot of money without a automotive tech opinion?
1) i dont get this "My car was running fine until i shut it off" Huh
1.5)chek or add more ground 0 gauge or + to th bellhousing
2) if it dims U should measure batt voltaje and current to the stater
3)buy a new batt or borrow
4)if not the batt u should do the A B C D test of the starter to discharge
5)chek wires or just set a direct wire to your key lock(start) to starter to discharge
6)if it start voltaje charge to alternator if not A B C D E F test too.
$$$$$$$$$$$$$$$$$$$$$44 Respect! Respect! Respect!
post a video,is so slow?600rpm at least to not fire with spark?more info?u raced?
Wave
02-25-2010, 08:21 PM
Sounds like the engine ground-strap is loose to me.
  Refreshed 20v blacktop first start.. Mylesmck 6 2,512 10-07-2024 07:55 AM
  Warm start problem DJexor 5 4,042 03-09-2023 10:15 AM
  Weak spark, doesn’t start. AlexFourTwenty 4 17,794 12-12-2017 03:35 AM
Last Post: AlexFourTwenty
  Won´t start AlexKTM 6 19,672 12-04-2017 10:05 PM
  Hard start issue kazi 5 8,207 05-23-2017 11:31 PM
Last Post: kazi
