car wont start, could it be what?
02-24-2010, 11:03 AM
Hello,
My car was running fine until i shut it off. and tried to start it. it wont start. the starter crank very very slow, like its not having enough power and all the light dims. i thought its was the alternator, so i got a new alternator. the car is still doing the same thing. so i bought a new battery. and the car is still doing the same thing. and finally i bought a new starter and its doing the same thing..now i don't know what the problem is. my guess maybe i have a bad grounding to the engine or something. the start is trying its hardest to crank. maybe i have a crack on the flywheel teeth to the start.. |
02-24-2010, 11:59 AM
Did you try running a + cable directly to the starter? If it starts then you know that you have a short somewhere in the system.
02-24-2010, 12:17 PM
What noHachi said.
+ Check all ground wiring going to the engine. Kp62 - 135hp Ae86 - 135hp C32 Laurel - 440hp C32 Laurel - 125hp |
02-24-2010, 03:14 PM
also check the plug (and wires) from your alternator, i had a similar problem a few years ago in my red hachi, my starter did the same as yours . all wires are circuted, because of the years the cable isolation wasn´t good any more, i had luck that it doesnt start to burn.....
greets |
02-25-2010, 04:55 AM
braq Wrote:Hello, dude omg u spent alot of money without a automotive tech opinion? 1) i dont get this "My car was running fine until i shut it off" 1.5)chek or add more ground 0 gauge or + to th bellhousing 2) if it dims U should measure batt voltaje and current to the stater 3)buy a new batt or borrow 4)if not the batt u should do the A B C D test of the starter to discharge 5)chek wires or just set a direct wire to your key lock(start) to starter to discharge 6)if it start voltaje charge to alternator if not A B C D E F test too. $$$$$$$$$$$$$$$$$$$$$44 post a video,is so slow?600rpm at least to not fire with spark?more info?u raced? |
02-25-2010, 08:21 PM
Sounds like the engine ground-strap is loose to me.
Refreshed 20v blacktop first start.. | Mylesmck | 6 | 536 |
Warm start problem | DJexor | 5 | 2,168 |
Weak spark, doesn’t start. | AlexFourTwenty | 4 | 14,921 |
Won´t start | AlexKTM | 6 | 16,605 |
12-04-2017 10:05 PM Last Post: banpei |
Hard start issue | kazi | 5 | 6,565 |
05-23-2017 11:31 PM Last Post: kazi |
