clutches and spring washers position in 2 Way TRD diff????
08-25-2011, 01:40 AM
Hi mates
I'm going to rebuild my LSD, and i have a doubt: I saw others LSDs that have only one (per side) "spring washer" or others that have two (one spring washer inside, all clutches and the other one outside) in my 2 Way TRD, when i scrapped it i could see that all clutches were inside and the two spring washers outside...is it the correct position in the 2W TRD? Anybody has an "instructions plane"? Thanks! ![]() ![]() |
08-25-2011, 03:38 AM
clutches and spring washers position in 2 Way TRD diff???? | |||
09-01-2011, 10:50 AM
Thanks Project D
Then were in the correct position Cheers ![]() ![]() |
ClutchMaxPRO Clutches - Good or Bad? | RolanTHUNDER | 0 | 1,227 |
Kaaz 1.5 way Diff - Driveshaft Compatability | chrisae86 | 1 | 2,471 |
Help needed: is it 1 way or 1.5way LSD | Dino86 | 2 | 3,791 |
Gearbox and Diff options | MIGGZFSU | 35 | 29,248 |
03-26-2017 12:00 AM Last Post: MIGGZFSU |
Tomei 16V poncams + Tomei technical trax 1.5 way LSD | Lt86 | 22 | 20,580 |
09-16-2016 09:56 PM Last Post: Alex170984 |
