converting afm to map
08-16-2007, 02:10 PM
I would like to convert my blue top 4age from AFM to MAP.
What do I need?
MAP sensor
ECU?
08-16-2007, 02:59 PM
As far as I know, if you have a Swiss afm hachi with 4agec (note the C), you won't gain much power with this type of conversion.
To obtain the same power that map sensored hachies have, you should use also the pistons from map sensored hachi.
The pistons used in Swiss hachies are different (lower compression) that the ones used in map spec. 4age.
Regards
Andrej
  Converting Jap Spec wing mirrors to UK spec chrisae86 5 2,396 04-12-2022 11:03 PM
Last Post: chrisae86
  AFM to Map Conversion ps13michi 3 3,226 01-06-2022 10:34 AM
Last Post: ps13michi
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,158 02-10-2020 06:39 PM
Last Post: Power_uP
  extracted freedom ecu 16v ignition map ditn 7 8,905 08-22-2016 10:01 AM
Last Post: ditn
  Bluetop AFM with air filter izanagi 4 7,111 04-29-2016 07:29 PM
