cool lower radiator hose
11-28-2016, 04:46 PM
Hello, today the radiator was removed because it was leaking and had to be fixed and the coolant changed with new. The problem is that after the installation we started the car and let it run for about 15 minutes.The upper hose started to get hot eventually but the lower one was slightly warm at best.
Does this sound normal to you? The car has an old two row copper radiator and the temp is functioning properly (the operating temp shows in the middle on the gauge same ten years now and never overheats) at least that is what the temp gauge shows..... Any suggestions? ALWAYS SIDEWAYS!!!!! |
11-28-2016, 05:13 PM
Upper hose getting hot eventually is the thermostat opening allowing hot water to go to radiator. Cool bottom hose is normal operation after the hot water has passed through the radiator.
11-28-2016, 10:13 PM
(11-28-2016 05:13 PM)totta Crolla Wrote: Upper hose getting hot eventually is the thermostat opening allowing hot water to go to radiator. Cool bottom hose is normal operation after the hot water has passed through the radiator.Thanks for the answer, there wasn't much time left today so i will check if the thermostat is working properly tomorrow but from what i remember it seemed that it doesn't circulate the water even after a short drive when i checked again! ALWAYS SIDEWAYS!!!!! |
11-29-2016, 01:54 AM
Start the car from cold with the radiator cap removed. There should not
be any flow visible in the radiator. When the engine warms up and the thermostat opens, you should see the coolant start to flow in the header tank. If you see flow the thermostat is working. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
11-29-2016, 01:06 PM
(11-29-2016 01:54 AM)jondee86 Wrote: Start the car from cold with the radiator cap removed. There should notThank you all, the problem caused by a stuck thermostat i replaced it and works fine ALWAYS SIDEWAYS!!!!! |
Radiator & grill support panel (Levin) | FanIsHere | 5 | 2,099 |
11-14-2022 10:07 PM Last Post: Ivan141 |
Alu thick core radiator fitment | Gtsi-R | 5 | 2,931 |
01-26-2022 01:28 PM Last Post: Gtsi-R |
AE86 F20C swap - Radiator issue | mad.matt | 3 | 5,968 |
02-07-2018 05:14 PM Last Post: mad.matt |
fuel line hose from the pump | Wikizz | 4 | 6,056 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
Radiator oem or upgrade on racecar? | Jimmi The Kid | 5 | 5,799 |
