cracked fuel line
03-21-2005, 07:20 PM
cracked fuel line
Full line crack over the bloody wend,im up at college and 150 miles from,was told just cut out the cracked section and replace wit a rubber tube and put a dewbaly clip on both sides.
Would this be safe enoug and good enough to get me home?
03-21-2005, 08:22 PM
cracked fuel line
If you get it to stay there without leaking to much and drive carefully it shouldn't be no problem.
[Image: AEU86 AE86 - cracked fuel line]
03-21-2005, 09:22 PM
cracked fuel line
My fuel line crack too, and I use the sam rubber tube, and use on both sides two clips for safety. No problem.
1984 AE 86 Levin hatchback
1989 AE 92 GTi
2004 Kawasaki KLE 500
03-22-2005, 09:28 PM
cracked fuel line
as ong as you get a rubber fuel line and not a vacuum line you should be good, even for long applications
You have by far the ugliest hachi on the nicest rims in the world -Mux213
03-23-2005, 02:07 PM
cracked fuel line
We have got smoke again, that god its not from a fire, just from the tyres. Thumbs up!
Got it sorted yesterday.bloody hole was rite on top of the tank.had to take it out.such a handelin.Got there in the end.at one stage my neighbour thought i had got my lrgs caught under the car, when iwas tryin to push the tank back up
  fuel line hose from the pump Wikizz 4 7,725 10-16-2017 07:11 PM
Last Post: jdm86gtz
Bug brake line leaking - how to fix ? MC_JP 2 5,824 04-28-2014 09:47 PM
Last Post: MC_JP
  brake caliper/line fitting Eifelaner 9 14,996 04-15-2013 11:38 AM
Last Post: Eifelaner
  Vacuum Sensor/line hook up help. Nanaki 15 31,536 04-20-2008 04:21 PM
Last Post: parrot
  20V Vacuum Line Help Needed domi 4 7,818 06-24-2007 09:23 AM
Last Post: evfan42
