cylinder head.
05-04-2011, 06:34 AM
cylinder head.
Hi, I just bought my first ae86 2 days ago so im very new to this car. I bought it with the cylinder head off and found outs its warped too much to repair. The cylinder is the sohc. I was wondering what are my options for a new cylinder head. I want to ask if a dohc would bolt up to it. thanks for any info.
05-04-2011, 11:34 AM
cylinder head.
So you bought an AE85 with a 3A engine?
[Image: AEU86 AE86 - cylinder head.]
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
05-04-2011, 06:09 PM
cylinder head.
Think that is 4AC on your picture, other option that AE85 can have.
Anyway, it's not AE86.
05-04-2011, 08:15 PM
cylinder head.
4ac= ae86 right? not ae85
Check your chassiscode :wink:
05-04-2011, 09:13 PM
cylinder head.
To answer your question, it is possible:
http://www.aeu86.org/viewtopic/20v-head-...ble/t/8123
Also a 3AGZE has been done:
http://www.aeu86.org/viewtopic/opex-ae85...ess/t/5753
05-05-2011, 05:45 AM
cylinder head.
i pretty sure its an ae86. I see it stamped on the firewall. the engine looks the same as the one on the picture though. Like I said i completly new to this vehical.
05-05-2011, 05:48 AM
cylinder head.
oh and im pretty sure its a 4a-c engine
05-05-2011, 07:33 AM
cylinder head.
Sry, thought there is no AE86 with 4AC.
Does it have rear disc brakes and LSD?
What is transmission code ?
05-05-2011, 07:53 AM
cylinder head.
i know its got drums in the back. dont know if its lsd or the transmission code. It is a 5 speed. where would i find the transmission code? how can i find out if its lsd without opening the rear end?
05-05-2011, 10:45 AM
cylinder head.
Check the aluminium tag on the firewall. There should be a line with trans/axle saying for example "T50 T292"
Post it here and we´ll be able to tell you more Smile
  4AGE cylinder head plug removal Ivan141 5 2,367 09-30-2023 09:47 PM
  Brake advice - master cylinder mannix20vt 12 14,777 08-21-2017 03:21 PM
Last Post: Project D
  Correct connection brake master cylinder? bozu 5 7,601 07-26-2015 12:28 PM
Last Post: bozu
  torque setting head cylinder bolts izanagi 1 5,101 05-29-2015 01:23 AM
  Dimensions clutch master cylinder bozu 2 6,365 04-16-2015 07:11 AM
Last Post: bozu
