cylinder head.
05-04-2011, 06:34 AM
cylinder head.
Hi, I just bought my first ae86 2 days ago so im very new to this car. I bought it with the cylinder head off and found outs its warped too much to repair. The cylinder is the sohc. I was wondering what are my options for a new cylinder head. I want to ask if a dohc would bolt up to it. thanks for any info.
05-04-2011, 11:34 AM
cylinder head.
So you bought an AE85 with a 3A engine?
05-04-2011, 06:09 PM
cylinder head.
Think that is 4AC on your picture, other option that AE85 can have.
Anyway, it's not AE86. |
05-04-2011, 08:15 PM
cylinder head.
4ac= ae86 right? not ae85
Check your chassiscode :wink: |
05-04-2011, 09:13 PM
cylinder head.
To answer your question, it is possible:
http://www.aeu86.org/viewtopic/20v-head-...ble/t/8123 Also a 3AGZE has been done: http://www.aeu86.org/viewtopic/opex-ae85...ess/t/5753 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
05-05-2011, 05:45 AM
cylinder head.
i pretty sure its an ae86. I see it stamped on the firewall. the engine looks the same as the one on the picture though. Like I said i completly new to this vehical.
05-05-2011, 05:48 AM
cylinder head.
oh and im pretty sure its a 4a-c engine
05-05-2011, 07:33 AM
cylinder head.
Sry, thought there is no AE86 with 4AC.
Does it have rear disc brakes and LSD? What is transmission code ? |
05-05-2011, 07:53 AM
cylinder head.
i know its got drums in the back. dont know if its lsd or the transmission code. It is a 5 speed. where would i find the transmission code? how can i find out if its lsd without opening the rear end?
05-05-2011, 10:45 AM
cylinder head.
Check the aluminium tag on the firewall. There should be a line with trans/axle saying for example "T50 T292"
Post it here and we´ll be able to tell you more 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,018 |
Brake advice - master cylinder | mannix20vt | 12 | 13,878 |
Correct connection brake master cylinder? | bozu | 5 | 7,174 |
torque setting head cylinder bolts | izanagi | 1 | 4,865 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
Dimensions clutch master cylinder | bozu | 2 | 6,050 |
04-16-2015 07:11 AM Last Post: bozu |
