cylinder head dimensions
06-19-2010, 12:33 PM
Does anyone know if there is a quick way of telling if a head has been skimmed ?
Some manufacturers give a measuring point and minimum allowable dimension.
Thanks,
TC
06-20-2010, 02:18 AM
totta Crolla Wrote:Does anyone know if there is a quick way of telling if a head has been skimmed ?
Thanks,
TC
as far i understood Smile
yes ,are 3 to 5 depends of the engine (not specified by you)
and you can see it,depending the model and year of the engine
like a groove.or shop mark.
Hurray! Hurray!
[Image: AEU86 AE86 - cylinder head dimensions]
06-20-2010, 09:39 PM
not specified because I thought it would be obvious.... 4age 16v...
Hurray!
Anyway I think I got what you are saying but can you tell me where the marks are and what the stock dimensions are ?
06-20-2010, 10:58 PM
measure combustion chambers volume. The easiest way. I wouldn't run under 35cc/ea. if you're not runnin high octane fuel, good ignition control and knock sensor. Stock are 39cc/ea.
hope it helps
IF Carlsberg made an AE86, then it would be propably the best car in the world...
06-20-2010, 11:16 PM
''hope it helps''
Yes it does thanks. Lots.
If just 4cc is the window then measuring the chamber volume has got to be crucial to a reliable build.
07-03-2010, 01:53 PM
even 2cc is massive so yes put some grease around the valves and fill the chamber up to see where it is
07-06-2010, 06:38 AM
Stock are NOT 39cc.... at least not on the 3 heads I've checked.
Stock appears to be 36.5cc to 37cc. 39cc may be after someone has de-shrouded around the valves.
Dan -
07-06-2010, 10:12 AM
oldeskewltoy Wrote:Stock are NOT 39cc.... at least not on the 3 heads I've checked.
Is there something wrong with this picture or is it just me? Shouldn't the numbers increase as the fluid level goes up filling the pipe? Dumb question
SFD
07-06-2010, 12:08 PM
it's a burette at the beginning you fill it up (top is zero) - then you start letting fluid into the chamber to find out the volume by reading the value Wink
07-06-2010, 12:15 PM
Great! So no spilling and better accuracy. I shall have to get one when the time comes... Cheers! Respect!
SFD
  4AGE cylinder head plug removal Ivan141 5 2,021 09-30-2023 09:47 PM
  Brake advice - master cylinder mannix20vt 12 13,878 08-21-2017 03:21 PM
Last Post: Project D
  Correct connection brake master cylinder? bozu 5 7,174 07-26-2015 12:28 PM
Last Post: bozu
  Quick question - Brake Pad Dimensions Lt86 2 5,269 06-07-2015 12:08 AM
Last Post: jondee86
  torque setting head cylinder bolts izanagi 1 4,866 05-29-2015 01:23 AM
