cylinder head dimensions
06-19-2010, 12:33 PM
Does anyone know if there is a quick way of telling if a head has been skimmed ?
Some manufacturers give a measuring point and minimum allowable dimension. Thanks, TC An analogue brain in a digital World |
06-20-2010, 02:18 AM
totta Crolla Wrote:Does anyone know if there is a quick way of telling if a head has been skimmed ? as far i understood yes ,are 3 to 5 depends of the engine (not specified by you) and you can see it,depending the model and year of the engine like a groove.or shop mark. |
06-20-2010, 09:39 PM
not specified because I thought it would be obvious.... 4age 16v...
Anyway I think I got what you are saying but can you tell me where the marks are and what the stock dimensions are ? An analogue brain in a digital World |
06-20-2010, 10:58 PM
measure combustion chambers volume. The easiest way. I wouldn't run under 35cc/ea. if you're not runnin high octane fuel, good ignition control and knock sensor. Stock are 39cc/ea.
hope it helps IF Carlsberg made an AE86, then it would be propably the best car in the world... |
06-20-2010, 11:16 PM
''hope it helps''
Yes it does thanks. Lots. If just 4cc is the window then measuring the chamber volume has got to be crucial to a reliable build. An analogue brain in a digital World |
07-03-2010, 01:53 PM
even 2cc is massive so yes put some grease around the valves and fill the chamber up to see where it is
07-06-2010, 06:38 AM
Stock are NOT 39cc.... at least not on the 3 heads I've checked.
Stock appears to be 36.5cc to 37cc. 39cc may be after someone has de-shrouded around the valves. Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-06-2010, 10:12 AM
oldeskewltoy Wrote:Stock are NOT 39cc.... at least not on the 3 heads I've checked. Is there something wrong with this picture or is it just me? Shouldn't the numbers increase as the fluid level goes up filling the pipe? SFD |
07-06-2010, 12:08 PM
it's a burette at the beginning you fill it up (top is zero) - then you start letting fluid into the chamber to find out the volume by reading the value
AE86 ex-daily |
07-06-2010, 12:15 PM
Great! So no spilling and better accuracy. I shall have to get one when the time comes... Cheers!
SFD |
4AGE cylinder head plug removal | Ivan141 | 5 | 1,999 |
Brake advice - master cylinder | mannix20vt | 12 | 13,874 |
Correct connection brake master cylinder? | bozu | 5 | 7,156 |
Quick question - Brake Pad Dimensions | Lt86 | 2 | 5,257 |
06-07-2015 12:08 AM Last Post: jondee86 |
torque setting head cylinder bolts | izanagi | 1 | 4,860 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
