dash lights problem
10-23-2006, 09:45 PM
dash lights problem
hey there i have a Trueno a 1984 model
having a problem with the dash lights
all the the emergancy lights light up
like handbrake low petrol etc etc
but none of the back lights work
for the speedo petrol or revs
any ideas?
i have the complete dash out at the minute
all the bulbs were ok except 2
the othe ones worked though so they should have lighted up
quite annoying hile driving at night i cant see what speed i am doing
[Image: AEU86 AE86 - dash lights problem]
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
10-23-2006, 09:52 PM
dash lights problem
It might be the rheostat switch (i don't have one but i guess you do) if i'm not mistaking this is "on the way to ground" coming from the bulb.
So check if you have a supply power to the bulbs (check fuse if none!) and if this is ok try to shortcut the rheosat switch.
[edit: even if the rheostat would be in series with the postive side of the bulb (i don't really grasp the diagram somewhere else on this site) you could test it by shortcutting]
10-23-2006, 10:34 PM
dash lights problem
Here you have the lightswitch diagram:
But I can't find the wiring diagram for the dash. Undecided
10-23-2006, 10:42 PM
dash lights problem
EE80 has it right on the money. Your rheostat (potentiometer whatever) is faulty, just fixed this on my car by taking the wire out of the connector and shorting it to the nearest groundwire I could find (on some un-used connector behind the dash cover). This way your backlights will work at full intensity, without adjustability. I'll be trying to fix mine once I put my spare switch in.
10-24-2006, 10:56 AM
dash lights problem
It's nice that the AE86 and MGB have some things in common... Makes it easier for me to diagnose electrical system faults :-)
02-03-2007, 08:27 PM
dash lights problem
time to revive a dead topic
just getting round to looking at this now
what is the rheostat switch?
is it the actual switch used to turn the lights on and off?
we are stuck as to what we are looking for Sad
02-03-2007, 08:36 PM
dash lights problem
The rheostat switch is the big round ring around the one to switch on the lights. Wink
02-03-2007, 08:48 PM
dash lights problem
banpei Wrote:The rheostat switch is the big round ring around the one to switch on the lights. Wink
thought so
why not just call it a bloody light switch lol
02-03-2007, 09:42 PM
dash lights problem
Because it's not a light switch, it's a rheostat ;-) Rheostats are used to set how bright the light is, light switches just switch lights on or off. But then I guess you noticed that as well :-)
You can leave the rheostat switch out when it's broken which will make the dash lights work at full brightness.
02-03-2007, 09:50 PM
dash lights problem
and how do you do that?
is it possable to remove the rheostat and how?
  Digital Dash evfan42 190 264,516 05-03-2024 06:44 PM
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 8,287 12-19-2021 11:58 PM
Last Post: gh0st
  Dash Waning Lights pack 7 4,387 10-06-2021 01:00 PM
Last Post: pack
  Trueno Digital dash kph to mph Bojack 3 7,129 11-21-2018 12:27 AM
Last Post: kazi
  Custom Dash Cluster kazi 14 20,424 10-24-2017 09:05 PM
Last Post: kazi
