differential lock %
04-11-2013, 02:26 PM
differential lock %
This time Im trying to collect differential data.
But I want to focus on lock percentage. I know the stock car was available with open and LSD diff's But I am unable to fint what was: - side bearing preload - power-side lock % - coast-side lock % Could You please help, and share some information ? |
04-11-2013, 06:01 PM
differential lock %
There is quite a bit of information available in the factory service manual.
Besides the FSM, you can also trackdown the TRD Bible. This has quite a bit of useful information, and it is available digitally...... Finally, there is a newer TRD publication I've not yet seen digitally... here is a photo of its cover ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-11-2013, 11:18 PM
differential lock %
I currently have two books and two FIA homologations.
There are some info but unfortunately not things about which I ask. I have FSM and TRD Bible, Im biding two other books in GB now. And I just won auction in PL. We will see... ...anyway the book that You espouse looks very promising - but I dont think that it is available in Poland :-/ |
04-12-2013, 08:10 PM
differential lock %
oldeskewltoy
That book is a summary of all suspension pieces for Toyotas or a vehicle specific book? ![]() |
04-12-2013, 11:41 PM
differential lock %
Sgonzalez Wrote:oldeskewltoy I don't know.... I take it at its word... it is a suspension data book... I believe it is all their offerings Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-17-2013, 06:37 PM
differential lock %
I found some open diff data from other RWD Toyota model with the same engine - side bearing preload is 0.8-1.4Nm for new bearing
and 0.4-0.7Nm for reused ones As far as I know, open diff was available on U.S. market, does someone have an US service manual to verify this data ? |
04-17-2013, 08:17 PM
differential lock %
damusto Wrote:I found some open diff data from other RWD Toyota model with the same engine - side bearing preload is 0.8-1.4Nm for new bearing You definitely want to get a factory service manual. I have the US manual and there isn't a side bearing preload old/new bearing listing*.... there IS a new/used pinion bearing preload...... 1.0-1.6N-m for new bearing, .5 -.8N-m for used bearing Side bearing pre-load is tighten and measuring backlash I'm not sure where you can get a factory service manual for your European based model... but the US FSM is available here - http://www.faxonautoliterature.com/ Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-17-2013, 10:01 PM
differential lock %
OK thanks a lot, when it comes to upper limit I found a description of rally Gr.A car where I found:
"2 way LSD (shimmed to 80%)" It does not change the fact that I'd to know how does look typical LSD options. |
Door lock disassemble | RWD | 3 | 2,313 |
03-17-2022 02:03 AM Last Post: Bean |
Rear Differential rebuild | chenfon | 10 | 10,097 |
Lower arm hits toe arm on lock... | fullybuiltmiata | 12 | 14,198 |
01-14-2016 11:52 PM Last Post: Deuce Cam |
Some information for those who are about to restore their differential | krullibull | 0 | 3,357 |
06-06-2015 12:44 AM Last Post: krullibull |
boot lock - alternatives | megabob | 2 | 4,818 |
12-14-2013 07:08 PM Last Post: Jan Pedersen |
