do efi 4age backfire?
03-17-2013, 03:12 AM
The throttle body has a vacuum pot that limits how quickly the throttle can return to the closed position. If it is defective or removed then the throttle plate closes tightly which causes a very high vacuum in the intake manifold, this draws all the fuel off the port walls of the intake. The raw fuel is then pump thru the cylinder into the exhaust manifold on the over run where there is sufficient oxygen in the exhaust system allowing the fuel burn i.e. back fire.
Dave W |
03-17-2013, 04:45 AM
Dave W Wrote:The throttle body has a vacuum pot that limits how quickly the throttle can return to the closed position. If it is defective or removed then the throttle plate closes tightly which causes a very high vacuum in the intake manifold, this draws all the fuel off the port walls of the intake. The raw fuel is then pump thru the cylinder into the exhaust manifold on the over run where there is sufficient oxygen in the exhaust system allowing the fuel burn i.e. back fire. Well explained ![]() Mine does the same when i release my foot off the gas pedal or when changing gears on high and low revs....and its a stock S3 4age... I always thought its back pressure from the exhaust ![]() Current - 2006 Run X RSI TRD spec Current - 1991 AE92 Conquest 4AGTE Ex - 1992 AE92 Corolla 4AGTE(175KW&295NM) Ex - 1983 1.8 SE Liftback(headworks and side draughts) |
03-17-2013, 06:18 AM
zenki Wrote:kpretro84 Wrote:zenki Wrote:Mine does it. Stock engine with straight pipe hks. what electronics? Map or AFM what ecu? Seems like your guys engine running correctly mines not? |
03-17-2013, 06:25 AM
Dave W Wrote:The throttle body has a vacuum pot that limits how quickly the throttle can return to the closed position. If it is defective or removed then the throttle plate closes tightly which causes a very high vacuum in the intake manifold, this draws all the fuel off the port walls of the intake. The raw fuel is then pump thru the cylinder into the exhaust manifold on the over run where there is sufficient oxygen in the exhaust system allowing the fuel burn i.e. back fire. hmmmmm ![]() |
03-17-2013, 07:47 AM
http://www.youtube.com/watch?v=nAmH7ITgBUY soooo jealous
03-17-2013, 07:23 PM
kpretro84 Wrote:zenki Wrote:kpretro84 Wrote:zenki Wrote:Mine does it. Stock engine with straight pipe hks. Map ハチロク ![]() |
03-17-2013, 09:11 PM
kpretro84 Wrote:Is your guys timing set 10 degrees btdc? without TE1 and E1 jumped? IShould be 10 deg BTDC jumped, or 15-16 deg BTDC not jumped. If it does not change when you take the jumper out, then you are not doing it right (conditions for entering diagnostic mode not met). Cheers... jondee86 |
03-17-2013, 10:38 PM
kpretro84 Wrote:Dave W Wrote:The throttle body has a vacuum pot that limits how quickly the throttle can return to the closed position. If it is defective or removed then the throttle plate closes tightly which causes a very high vacuum in the intake manifold, this draws all the fuel off the port walls of the intake. The raw fuel is then pump thru the cylinder into the exhaust manifold on the over run where there is sufficient oxygen in the exhaust system allowing the fuel burn i.e. back fire. Series 3 Twincam 16 valve ![]() Current - 2006 Run X RSI TRD spec Current - 1991 AE92 Conquest 4AGTE Ex - 1992 AE92 Corolla 4AGTE(175KW&295NM) Ex - 1983 1.8 SE Liftback(headworks and side draughts) |
03-20-2013, 07:36 AM
jondee86 Wrote:kpretro84 Wrote:Is your guys timing set 10 degrees btdc? without TE1 and E1 jumped? IShould be 10 deg BTDC jumped, or 15-16 deg BTDC not jumped. If it thats the one its working now chucked it in dignostic mode 10 deg engine ran even better thank you all its now backfiring ![]() ![]() |
03-20-2013, 09:18 AM
where's the facepalm smiley when you need it
![]() FABRICA MI DIEM, PVNC! |
What efi is compatible for swap on a carburator | mobsterk | 10 | 10,221 |
02-12-2010 02:36 AM Last Post: Chrisso |
What does the EFI Main Fuse do? | jeenyus | 4 | 8,127 |
06-03-2008 10:47 AM Last Post: banpei |
