do efi 4age backfire?
03-20-2013, 09:51 AM
It's probably done the ringlands
Cheapest option would be to install another engine but you might find the bores are not scored from the piston rings and you could just fit a replacement piston into your engine. To avoid this happening again check the ignition timing. Did it backfire much before you noticed the lack of power and excessive oil consumption ? An analogue brain in a digital World |
03-22-2013, 09:19 AM
duno what you guys going about ^ but the problem was intake. i had some air lick so when the throttle closes air was not shut off straight away.
03-22-2013, 04:09 PM
http://www.youtube.com/watch?v=8a4Bz6Pa4sY
I'd advise to hear it with headphones on max volume!! it backfired like this when the mapping wasn't correct. It was very funny for the first times, but it became real annoying after a few days, when you drive the car on public roads. and I think it was the thing which broke my header aswell.. |
03-22-2013, 09:10 PM
Ivan141 Wrote:where's the facepalm smiley when you need itI'll note that down as a must-have for the forum upgrade! 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
What efi is compatible for swap on a carburator | mobsterk | 10 | 9,373 |
02-12-2010 02:36 AM Last Post: Chrisso |
What does the EFI Main Fuse do? | jeenyus | 4 | 7,286 |
06-03-2008 10:47 AM Last Post: banpei |
