driveline vibration TE71
03-07-2014, 06:04 PM
Tried different wheels already? (stupid questions first ;-)
03-07-2014, 06:58 PM
Brand new... no reason why it should be the wheels...
03-07-2014, 10:36 PM
pack Wrote:They are not. Everything is checked, double checked actually!
Getting a bit tired....
Could also be some bearing in the gearbox...
Given the noise you are describing it could be diff bearings, crown wheel and pinion gears or rear wheel bearings More than likely the latter.
  Decently heavy vibration in fourth gear between 2000-2300rpm dinkers542 4 5,787 11-29-2014 12:27 AM
Last Post: dinkers542
  Problems installing yellow koni's in my TE71 liftback teun 12 16,319 11-09-2013 03:01 PM
Last Post: teun
  Will ae86 stock springs fit TE71 liftback ? Ryo 19 26,783 05-04-2011 05:21 AM
Last Post: ash16valve
  TE71: 2T-B engine thermostat opening temperature ? Ryo 1 3,686 04-06-2011 07:28 PM
Last Post: Ryo
  TE71 roll cage totta Crolla 3 5,485 02-04-2011 05:43 PM
Last Post: corolla4agze
