driveline vibration TE71
03-07-2014, 06:04 PM
Tried different wheels already? (stupid questions first ;-)
03-07-2014, 06:58 PM
Brand new... no reason why it should be the wheels...
03-07-2014, 10:36 PM
pack Wrote:They are not. Everything is checked, double checked actually! Given the noise you are describing it could be diff bearings, crown wheel and pinion gears or rear wheel bearings More than likely the latter. An analogue brain in a digital World |
Decently heavy vibration in fourth gear between 2000-2300rpm | dinkers542 | 4 | 5,479 |
11-29-2014 12:27 AM Last Post: dinkers542 |
Problems installing yellow koni's in my TE71 liftback | teun | 12 | 15,531 |
11-09-2013 03:01 PM Last Post: teun |
Will ae86 stock springs fit TE71 liftback ? | Ryo | 19 | 25,724 |
05-04-2011 05:21 AM Last Post: ash16valve |
TE71: 2T-B engine thermostat opening temperature ? | Ryo | 1 | 3,540 |
04-06-2011 07:28 PM Last Post: Ryo |
TE71 roll cage | totta Crolla | 3 | 5,231 |
02-04-2011 05:43 PM Last Post: corolla4agze |
