driveshaft center bearing issue
06-02-2012, 11:10 PM
i have total transplant 4AGE & part to my KE70, after two years+ my drive shaft center bearing start shake. wondering the KE70 center bearing set can fit into AE86 longshaft? wil there same inner shaft diameter?
06-03-2012, 03:46 AM
What do you mean by center bearing? differential bearing? diff input bearing?
AE86 and KE70 have different axle codes T for AE86 and iirc U for the KE70, therefore diff, axles, etc won´t fit into each other. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
06-03-2012, 12:00 PM
sorry for the unclear description, plz do refer drawing where part in circle. did u have any ideal on it? tq
06-03-2012, 01:54 PM
06-03-2012, 03:08 PM
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
06-12-2012, 08:05 PM
I had a same issue and I bought a malaysian similar center bearing and my mechanic took the outer shell of my old bearing setup and put it onto the new one.
Wana try and out? My issue was the center bearing had a bad play in it and the rubber dampers around it had lost its shape.. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
06-13-2012, 01:24 AM
Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-30-2012, 12:06 PM
Dear "Heshan", did u have more detail on the "modification"? if good with photo. (photo tells every thing)
tq heshan Wrote:I had a same issue and I bought a malaysian similar center bearing and my mechanic took the outer shell of my old bearing setup and put it onto the new one. |
PWR light issue and no brake fluid after winter storage | magpie | 10 | 2,602 |
AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 7,105 |
07-28-2022 10:48 PM Last Post: banpei |
Fuel pump issue | DJexor | 11 | 4,976 |
Restoring original pizzacutter center caps | banpei | 17 | 8,660 |
06-24-2021 10:58 PM Last Post: banpei |
Kaaz 1.5 way Diff - Driveshaft Compatability | chrisae86 | 1 | 2,322 |
05-10-2021 01:02 PM Last Post: Project D |
