engine problem again overheating this time !!!!
06-08-2009, 08:40 PM
Change your thermostat with a cold one. Mount up electric fans with a own pressure thats work on its own heat scale. Flush the system to get the air out. Check your pump that its spinning easily and its aligned properly.
This is my basic "diagnostic". Kp62 - 135hp Ae86 - 135hp C32 Laurel - 440hp C32 Laurel - 125hp |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,104 |
axle swap time how capable is a std crownwheel and pinion | fax0815 | 32 | 45,948 |
09-26-2013 08:33 PM Last Post: Lajoosh |
4AGE camshafts (again) | Alex170984 | 26 | 29,520 |
03-19-2013 02:41 PM Last Post: Alex170984 |
Engine problem developing any ideas? | phill 92 | 3 | 4,268 |
07-26-2012 11:47 PM Last Post: jondee86 |
4agZe problem solved - 99% IC problem | Okami | 41 | 35,805 |
07-12-2012 04:49 PM Last Post: Okami |
