engine problem again overheating this time !!!!
06-08-2009, 08:40 PM
Change your thermostat with a cold one. Mount up electric fans with a own pressure thats work on its own heat scale. Flush the system to get the air out. Check your pump that its spinning easily and its aligned properly.
This is my basic "diagnostic".
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
[Image: AEU86 AE86 - engine problem again overhe... time !!!!]
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 8,102 10-30-2013 11:18 PM
  axle swap time how capable is a std crownwheel and pinion fax0815 32 45,947 09-26-2013 08:33 PM
Last Post: Lajoosh
  4AGE camshafts (again) Alex170984 26 29,519 03-19-2013 02:41 PM
Last Post: Alex170984
  Engine problem developing any ideas? phill 92 3 4,267 07-26-2012 11:47 PM
Last Post: jondee86
  4agZe problem solved - 99% IC problem Okami 41 35,805 07-12-2012 04:49 PM
Last Post: Okami
