engine problem
10-03-2007, 10:42 PM
engine problem
my car is stock (swiss zenki) and ran 250.000 km. in the last week she had some problems starting, like if one piston was sleeping but after that it worked fine. Finally, today I was in the highway and around 3000rpm I hear a sound tac tac tac tac tac coming from the top of the engine, sound got quickly louder and louder...and then I noticed the car won't accelerate...temperature gauge was ok though so I stop it, check the engine, it was actually quite hot as the liquid in the reservoir was boiling and spitting out for like 5 mins! maybe temp gauge is gone... anyway the only thing I could do on the side of the highway was checking the spark plugs and one of them was very dirty of oil so I swapped them and tried to start the engine...it started but one piston is definitely not working so I went back home very slowly. where should I start?
10-04-2007, 03:07 AM
engine problem
Hey what's up?
Japanese hot summer is gone! Wea ![]() Since your car ran 250000km. Too much carbon on your piston head.Then got too much compression. If it happens, the pistons break or the valves melt. then you can't get any compression. At first take your head off. then you will see. P.S. my flywheel botls fucked up and I gotta take my crankshaft off. |
10-04-2007, 09:14 AM
engine problem
great to see you here!!
running_free86 Wrote:Hey what's up? wow...I wish I was there insted of (sh)Italy... running_free86 Wrote:Since your car ran 250000km. Too much carbon on your piston head.Then got too much compression. OK, I will try. running_free86 Wrote:P.S. my flywheel botls fucked up and I gotta take my crankshaft off. from the red car? that sucks... |
10-04-2007, 10:04 PM
engine problem
Its 100% that you should pull your head off...
It can be broken piston, broken valve, maybe headgasket? or so... |
10-05-2007, 05:57 PM
engine problem
4th cylinder has no compression...it's a broken piston
best solution? |
10-05-2007, 07:00 PM
engine problem
Cheap secondhand engine or expensive rebuild.
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,392 |
Engine problem developing any ideas? | phill 92 | 3 | 4,581 |
07-26-2012 11:47 PM Last Post: jondee86 |
4agZe problem solved - 99% IC problem | Okami | 41 | 37,642 |
Engine / cooling fluid problem need help asap... | Okami | 11 | 14,521 |
02-15-2011 01:34 PM Last Post: Okami |
coolant dissaperance, engine problem | Uzelac | 9 | 9,449 |
07-16-2010 03:37 PM Last Post: Uzelac |
