gas/brake pedal position
08-06-2008, 04:07 PM
Hi,
Is there some easy way to adjust the gas pedal position? Currently I have one of these USDM or something positions: brake and gas pedal do not line-up (gas pedal is further back). Kinda sucks for practicing heel-toe... anyone else had this same issue and fixed it? If so, how? |
08-07-2008, 04:43 AM
Take your gas pedal out and bend it. Problem solved. Also, while at it move it slightly closer to brake pedal if you've got a small foot.
08-07-2008, 09:20 AM
Yeah.... what he said
![]() pedal is still too far away from the brake !!! Cheers... jondee86 |
08-07-2008, 09:36 AM
Cool, thanks, I'll try that in a while
![]() Didn't think it could be that easy ![]() |
08-12-2008, 05:54 AM
What I did was weld a piece of metal to space it out more.
4age hitting gas too quick means engine stalls - what is the issue? | Ryo | 20 | 31,000 |
06-27-2018 11:15 PM Last Post: Ryo |
clutch pedal return spring | Eifelaner | 2 | 7,477 |
09-06-2013 10:21 AM Last Post: Apsogos |
3rd door support gas springs (stay) - worn out | max_ae86 | 5 | 6,480 |
09-01-2013 03:20 PM Last Post: Jezza_hr |
Clutch pedal problem | andee17 | 3 | 4,811 |
07-25-2013 11:57 AM Last Post: jondee86 |
Distributor position and cranking | pack | 13 | 20,243 |
07-01-2013 11:08 PM Last Post: pack |
