gas/brake pedal position
08-06-2008, 04:07 PM
Hi,
Is there some easy way to adjust the gas pedal position? Currently I have one of these USDM or something positions: brake and gas pedal do not line-up (gas pedal is further back).
Kinda sucks for practicing heel-toe... anyone else had this same issue and fixed it? If so, how?
08-07-2008, 04:43 AM
Take your gas pedal out and bend it. Problem solved. Also, while at it move it slightly closer to brake pedal if you've got a small foot.
08-07-2008, 09:20 AM
Yeah.... what he said Tongue Even if you have a large foot, the gas
pedal is still too far away from the brake !!!
Cheers... jondee86
08-07-2008, 09:36 AM
Cool, thanks, I'll try that in a while Big Grin
Didn't think it could be that easy Dumb question
08-12-2008, 05:54 AM
What I did was weld a piece of metal to space it out more.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  4age hitting gas too quick means engine stalls - what is the issue? Ryo 20 28,810 06-27-2018 11:15 PM
Last Post: Ryo
  clutch pedal return spring Eifelaner 2 7,177 09-06-2013 10:21 AM
Last Post: Apsogos
  3rd door support gas springs (stay) - worn out max_ae86 5 6,139 09-01-2013 03:20 PM
Last Post: Jezza_hr
  Clutch pedal problem andee17 3 4,586 07-25-2013 11:57 AM
Last Post: jondee86
  Distributor position and cranking pack 13 19,183 07-01-2013 11:08 PM
Last Post: pack
