help, engine dies at startup - (56k Warning - SOLVED)
05-22-2007, 11:11 AM
Post: #31
cheers - I'll take the notebook along and stay in touch...
05-22-2007, 01:19 PM
Post: #32
Bean Bandit Wrote:anyone any other last minute tips before I go to the garage?
Play around with distributor...
Let someone crank the car and while it's cranking you turn the distributor left and right.. try it couple of times and see what is happening.
One 4AGE after small rebuild refused to fire up.. and everything seemed perfect. Playing with distributor solved things..
Good luck Smile
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
05-22-2007, 03:14 PM
Post: #33
irishtwincam Wrote:-Check for air lock in fuel line.
-Loosen 22 on fuel rail, crank until fuel squirts out Big Grin
-----REMEMBER TO RETIGHTEN
couldn't find it in the manual, which bolt do you mean ? I'm very close now it starts and dies out again as if the was not enough fuel...
EDIT: ok fuelling is defo ok... the engine spluters briefly (2-3sec) then dies...
05-22-2007, 05:01 PM
Post: #34
ok so I set the timing as good as I could with the pictures and it's starts up briefly ~3 sec and then suts... if I push the throttle it shuts too... - i checked the vac hoses and they are fine so...
timing okish
timing belt ok
sparks ok
fuel ok
in those 3 sec startups it reaches around 1000rpm a bit more with little throttle befor the engin dies...
after 2 trys I need to wait for a while... guess it's flooded then...
anyone, i'm still at the garage and would love to change to the corolla from the slow Kia Picanto I have Banging head
05-22-2007, 05:52 PM
Post: #35
Man, check your grounds... (I had the similar problm), just do it...
If you took the head off you had to take off the ground wireing of the intake manifold. Check if that is back...
The engine must have fuel, spark and air... And if you have those 3 and still doesn't wont to fire up, do UMMMMMMMMMMMMMMM, breath in, breath out, save your nerves, close up the garage, come back after a few days (if possible, not alone), and check everything in school order...
Fingers crossed. I coudn't fire up my junk for 3 weeks, almost pushed it in the river... and we sat by the car, think about it and just ran it from top to bottom... Meshin helped with the wireing, we found the loose ground and WROM!
Just go slow and save your nerves...
PS
(voodoo doesn't help... I tryed that too Big Grin )
SNO-MO-BIRU project started- CHIRO
05-22-2007, 08:14 PM
Post: #36
hurray Smile - thanks mrgud Respect! , the ground did the trick... must have overlooked it burryed under the loom. Big Grin
Thumbs up!
purs like a kitten
05-22-2007, 08:38 PM
Post: #37
hehehe!!! Great man!!! I am so happy to hear that!
That shit took me 3 weeks of work and a shit load of nervs...
Glad to be of help! Hurray! Hurray! Wave
05-22-2007, 11:20 PM
Post: #38
Don't f*** bevlive the someone made same mistake like mrgud... Smile
Great you solved it...
05-22-2007, 11:24 PM
Post: #39
meshin Wrote:Don't f*** bevlive the someone made same mistake like mrgud... Smile
it hapens quite quickly if you don't activly think about refiting the ground as its under the chunky loom hidden away in a very narrow spot where you don't enjoy to work Smile
it's a pleasure to be on the road again... tomorrow I will do a small service (oil, plugs, water), fit my new mintex pads and go for a long good drive Smile
05-23-2007, 12:17 AM
Post: #40
Bean Bandit Wrote:it hapens quite quickly if you don't activly think about refiting the ground as its under the chunky loom hidden away in a very narrow spot where you don't enjoy to
You are lucky Smile ... mrgud, me .. and a lot of other people who helped took whole 3 weeks messing around till we found that loose ECU ground wire Banging head
  High-beam warning lamp Mylesmck 4 1,622 07-21-2023 07:44 AM
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 7,747 07-28-2022 10:48 PM
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 8,279 10-30-2013 11:18 PM
  AVO Suspension from MCN Motorsport warning 4000GT 1 3,875 07-19-2013 04:48 AM
Last Post: 4000GT
  How to: Repair low fuel warning sender Sanity Clause 2 37,375 11-22-2012 09:21 AM
User(s) browsing this thread: 15 Guest(s)
