help! if I don't fix I must sell Haichi!
02-23-2007, 09:57 PM
Hello, I Have an '84 sr5 that has a 3ac with a cracked block. I need to put another engine in it and don't want another 3ac. I was looking into swapping in a 4ag with dual carbs. What all is incorporated in this as far as modifications? I've searched and haven't come across this in particular. Can I do it with the stock steering knuckle? I know I have to do some electrical work. I have to fix car soon otherwise I have to sell and I really really dont want to sell it (I love this car). Any help would be much appreciated. Thanks!
02-23-2007, 10:14 PM
Heya,
Start with reading this: http://www.aeu86.org/viewtopic/carbureti...4ag/t/4426 thread about hooking up the ignition timing and stuff. Basically the 4AG should be bolt in and there should be no worries as far as steering goes. Your main problem will be electronics (I think covered in that thread but I'm not sure, I've never done this!) and things like fuel. Also you'll need something for exhaust ![]() Anyways, if you got the engine with carbs already and you know what you're doing, it should be a very doable swap.. Offcourse once you get it running you're going to find out the SR5 rear axle can't take the HP, the suspension needs upgrading and the brakes are questionable if your carbed engine produces good power. But they are all things that you can do in due time.. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
Mistlamps don't fit | gh0st | 1 | 2,428 |
10-14-2021 09:00 PM Last Post: banpei |
Anyone know how to fix the digital clock? | kawo | 0 | 3,488 |
05-02-2014 08:54 AM Last Post: kawo |
Dome light fix | Jezza_hr | 2 | 5,755 |
05-01-2014 10:14 PM Last Post: Jezza_hr |
brake line leaking - how to fix ? | MC_JP | 2 | 4,523 |
04-28-2014 09:47 PM Last Post: MC_JP |
How to fix a floating idle on a Toyota 4A-GE motor | Homem Bomba | 8 | 24,486 |
08-27-2013 12:55 AM Last Post: jondee86 |
