help needed with cams please
10-10-2010, 12:32 PM
ok my engine
4age bluetop trd 0.8 headgasket ported and polished 4 branch exhaust manifold now i equired a set of cams toda 256/7.9 and 264/7.9 i also have toda adj cam pulleys now which cam do i put to int and which to exhaust so the car still idles well for street use? and what is the ideal degree setup for these? thaqnks for your help in advance |
10-10-2010, 01:24 PM
I'd go with 264 on the intake side...
are you gonig to use the stock ECU still? here you can find the datasheet of the HKS cams - you can use theire timing table to start with AE86 ex-daily |
10-10-2010, 04:37 PM
yeah using the standard ecu
10-10-2010, 06:48 PM
Read up on a concept called "dynamic compression ratio", this may help you decide which cam you want where.
*IF* the head is unported, I'd recommend the 256 cam on the intake side, and the 264 on the exhaust side. Here are the Toda timing sheets 256 264 Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-10-2010, 07:33 PM
So toda suggests 110/110 stock timing with both the 256 and 264 cams?
According to club4ag tech ref TRD timing for 264 cam is Intake 106° ATDC Exhaust at 116°BTDC. Bigger cam on teh exhaust improves midrange, big cam on intake improves top end. http://www.skynet.ie/~eireae86 |
Help needed | totta Crolla | 3 | 3,902 |
05-15-2020 10:07 AM Last Post: totta Crolla |
TUV RHD AE86 Germany (help please) | 4dori | 9 | 7,038 |
07-17-2019 07:42 PM Last Post: Hachigo83 |
Some wiring help needed | DJexor | 5 | 5,494 |
Help needed: is it 1 way or 1.5way LSD | Dino86 | 2 | 3,643 |
Shim size for AM cams | kazi | 4 | 5,207 |
