help needed with cams please
10-10-2010, 12:32 PM
ok my engine
4age bluetop
trd 0.8 headgasket
ported and polished
4 branch exhaust manifold
now i equired a set of cams toda 256/7.9 and 264/7.9 i also have toda adj cam pulleys
now which cam do i put to int and which to exhaust so the car still idles well for street use? and what is the ideal degree setup for these?
thaqnks for your help in advance
10-10-2010, 01:24 PM
I'd go with 264 on the intake side...
are you gonig to use the stock ECU still?
here you can find the datasheet of the HKS cams - you can use theire timing table to start with
10-10-2010, 04:37 PM
yeah using the standard ecu
10-10-2010, 06:48 PM
Read up on a concept called "dynamic compression ratio", this may help you decide which cam you want where.
*IF* the head is unported, I'd recommend the 256 cam on the intake side, and the 264 on the exhaust side.
Here are the Toda timing sheets
256
[Image: AEU86 AE86 - help needed with cams please]
264
Dan -
10-10-2010, 07:33 PM
So toda suggests 110/110 stock timing with both the 256 and 264 cams?
According to club4ag tech ref TRD timing for 264 cam is
Intake 106° ATDC
Exhaust at 116°BTDC.
Bigger cam on teh exhaust improves midrange, big cam on intake improves top end.
http://www.skynet.ie/~eireae86
  Help needed totta Crolla 3 4,123 05-15-2020 10:07 AM
Last Post: totta Crolla
  TUV RHD AE86 Germany (help please) 4dori 9 7,428 07-17-2019 07:42 PM
Last Post: Hachigo83
  Some wiring help needed DJexor 5 5,755 05-18-2019 01:50 PM
Last Post: DJexor
  Help needed: is it 1 way or 1.5way LSD Dino86 2 3,846 05-17-2019 09:08 AM
  Shim size for AM cams kazi 4 5,412 12-18-2017 05:34 PM
