20v distributor
01-20-2008, 08:48 PM
20v distributor
When running a 20v engine ("modified" bulkhead) with a standard distributor is there enough room to remove the cap and change the rotor arm ?
01-20-2008, 09:38 PM
20v distributor
That would depend on how "modified" the bulkhead is
![]() Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
01-21-2008, 01:42 PM
20v distributor
Jan Pedersen Wrote:That would depend on how "modified" the bulkhead is mmm.. I've seen rotor arms break on a rally car before, a two minute fix normally. Taking the engine out on a rally, might be a problem ![]() An analogue brain in a digital World |
16v distributor hole plug | harkes | 8 | 10,416 |
Changing distributor when carb 4age | izanagi | 14 | 17,722 |
Machining Pistons to run 20v head... And FCR's on a 20v? | PazzaAE86 | 2 | 5,611 |
Distributor position and cranking | pack | 13 | 21,196 |
07-01-2013 11:08 PM Last Post: pack |
weak spark. new distributor? please help. | stasis_dc5 | 3 | 7,838 |
04-11-2011 12:35 AM Last Post: fax0815 |
