help on the charcoal canister
01-21-2008, 01:03 AM
look at this please.
took this out.:confused: dont know what its for, but i think it is no use. originally it is red colour.:nod: this is other said... you might need that. or when it gets warmer again petrol will spill from those lines. its pretty much the tank breather. called the charcoal canister. this is my reply. AR ????? fuel comes out form the pipe..... burn....fire... so should i put it back ?? what breather is it? fuel tank breather ?? |
01-21-2008, 05:17 AM
Yeah you should use the charcoal canister or your car will smell of petrol all the time.
01-22-2008, 01:08 AM
I removed mine, I put a piece of fuel pipe from the metal breather line through A grommet to finish under the wing.
The fuel tank has another breather that works when the canister is full anyway. This is used when the car is parked in the sun for long periods but without the engine running |
What's in the Canister? | adenAE86 | 3 | 4,798 |
12-17-2009 08:34 PM Last Post: Bean |
