how to connect a fuel pump
08-13-2007, 01:01 PM
hi a am running a weber carb ,,,i need to connect my fuel pump but need to no if it is first the fuel filter then pump or first the pump the petrol filter when i run the hose to the carb
08-13-2007, 02:04 PM
You must have filter between tank and pump and it will not hurt to use another one after the pump (I always use two filters that way).
20v BT - which oil pump? | Mylesmck | 4 | 2,866 |
Fuel pump issue | DJexor | 11 | 5,328 |
fuel line hose from the pump | Wikizz | 4 | 6,107 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
4age smallport oil pump in bigport engine? | ditn | 2 | 8,274 |
12-06-2014 08:10 PM Last Post: ditn |
Oil pump question | megabob | 2 | 4,991 |
03-05-2014 05:37 AM Last Post: oldeskewltoy |
