how to connect a fuel pump
08-13-2007, 01:01 PM
hi a am running a weber carb ,,,i need to connect my fuel pump but need to no if it is first the fuel filter then pump or first the pump the petrol filter when i run the hose to the carb
08-13-2007, 02:04 PM
You must have filter between tank and pump and it will not hurt to use another one after the pump (I always use two filters that way).
  20v BT - which oil pump? Mylesmck 4 2,833 06-21-2022 04:51 PM
Last Post: pack
  Fuel pump issue DJexor 11 5,221 04-29-2022 05:45 AM
  fuel line hose from the pump Wikizz 4 6,068 10-16-2017 07:11 PM
Last Post: jdm86gtz
  4age smallport oil pump in bigport engine? ditn 2 8,221 12-06-2014 08:10 PM
Last Post: ditn
  Oil pump question megabob 2 4,950 03-05-2014 05:37 AM
Last Post: oldeskewltoy
