howdy all from nz
06-15-2012, 05:04 AM
howdy all from nz
hey guys and gals,
my names james, im 23 from auckland new zealand currently i own an ae92 corolla sedan gt, with a 7agze running 5psi i would very much like to set her on fire, one day i will own an 86 like ive always wanted but moneys tight atm |
06-15-2012, 04:44 PM
howdy all from nz
lol, set her on fire?
Welcome! ハチロク |
06-16-2012, 01:47 AM
howdy all from nz
Yea im having big time fuelling issues
06-16-2012, 04:37 AM
howdy all from nz
What sort of fuelling issues??
06-16-2012, 04:42 AM
howdy all from nz
Over fueling and fowling the plugs. Found out its got a 4age ecu and gze intake and injectors. Ive just got a gze ecu so im hoping that will solve the problem and i need to lower the fuel pressure as its about 90psi atm
06-16-2012, 04:44 AM
howdy all from nz
sounds like a good start. if you have any more issues i hope i can help.
06-16-2012, 05:30 PM
howdy all from nz
welcome
06-21-2012, 07:13 AM
howdy all from nz
Ok so im stumped guys.
I drove this car back from rotorua. About 5 hours. Ran horrid but didnt miss a beat except for at high rpm. Now its running like a pig it starts and runs ok when cold seems to missfire alot though but when it gets warm it dies? Any ideas? Btw i didnt do my homework and have gone and got an ae101 4agze ecu clever i know. So yea any ideas would be awesome. Ooo it also idles about 1000 rpm when cold. So i think ill adjust the throttle screww a bit and see if that helps |
06-21-2012, 01:10 PM
howdy all from nz
Might be the ignition coil.. quite a usual failure mode for it to work when cold and then crap out once it gets hot.
06-21-2012, 11:10 PM
howdy all from nz
ok so ignition coil, ill test that out,
could it be headgasket? it seems to be only losing compression on #2 and #3 cylinders |
Nice to meet you all! | rodri_vp | 4 | 3,063 |
12-24-2021 04:56 AM Last Post: rodri_vp |
Hail to all | Patrick Ross | 33 | 22,023 |
04-03-2018 12:38 AM Last Post: Patrick Ross |
hello all | greed1 | 7 | 8,344 |
08-11-2014 11:11 PM Last Post: greed1 |
Greeting To All | Mr Beams | 5 | 6,473 |
07-08-2013 11:06 AM Last Post: Mr Beams |
hi to you all Hachi drivers!!!!!! | MajkL | 13 | 11,384 |
12-13-2010 03:20 AM Last Post: Xerius |
