inlet manifold
09-28-2010, 01:23 PM
inlet manifold
Hi all
My inlet manifold has cracked and is beyond welding repair, causing the engine to have a very lumpy idle, so it would be more economically to buy a second hand inlet manifold.
My engine is a AE92 bigport TVIS. The question i want to ask is can i fit a normal Bluetop inlet manifold? Are the inlet manifold between the Bluetop and Redtop interchangeable? Are they the same?
All help appreciated.
There is only one true Nismo at AEU86
09-28-2010, 02:32 PM
inlet manifold
Manifolds are interchangeable between bigport (TVIS) engines.
They are not interchangeable between bigport (bluetop) and smallport (redtop) engines. So maybe first try and figure out what you have.
09-28-2010, 04:05 PM
inlet manifold
Weren't all 4AGE in AE92 smallport/redtop ?
09-28-2010, 07:56 PM
inlet manifold
http://www.aeu86.org/index/technical-faq...post=58121
Wave
09-29-2010, 02:12 AM
inlet manifold
NoHachi Wrote:Manifolds are interchangeable between bigport (TVIS) engines.
Thanks alot for the info Smile
09-29-2010, 02:17 AM
inlet manifold
Uzelac Wrote:Weren't all 4AGE in AE92 smallport/redtop ?
AFAIK in the UK, the AE92 from the Corolla GTI. The earlier cars had the bigport (TVIS) engine and the later versions had the smallport engines.
  Smallport inlet manifold totta Crolla 6 3,421 01-17-2022 05:14 PM
  4age blue top from MR2 same intake manifold? dinkers542 8 10,529 11-02-2014 05:24 PM
Last Post: ditn
  4AGTE turbo manifold questions daveskatesallday 3 4,997 08-13-2013 07:38 PM
Last Post: daveskatesallday
  20v itb inlet manifolds totta Crolla 24 26,686 12-14-2012 12:21 PM
  20v silvertop exhaust manifold on 16v 2nd version tvis motor Apsogos 17 22,460 11-22-2012 11:15 PM
Last Post: Apsogos
