is this a smallport or bigport
11-09-2005, 10:26 PM
DJexor: as i recall, fensport.co.uk are selling reconditioned 4a-g engines. A 87-89 redtop goes for 300 UK pounds i think..
11-10-2005, 12:21 PM
yes billzilla says that the combustion chamber on both engines are identical,
the head is lowered and i plan to use metal head gasket,
but the benefit is to better the flow in mid range,
apolan:87-89are bigports
http://www.86ers.org
11-10-2005, 12:51 PM
a redtop is a '91 engine isn't it?
but I can ask them (fensport)
thanks
[Image: AEU86 AE86 - is this a smallport or bigport]
11-10-2005, 01:29 PM
The 87-89 redtop engine is the 7 rib block with the bigport tvis head.
The engines are low milage used Japanese engines for £395
they also do low milage bluetops at £295 but shipping them anywhere else but the uk would cost lots.
I fitted a phase II engine in the past that i got fom them, the thing to remember is that these are fwd engines and need a few bits and pieces swapped over so you can fit them.
..edit.. don't forget to add 17.5% to the prices for tax within the EC
11-21-2005, 11:55 AM
ok the head was bigport from an 88gti, but complete with polished ports, matched to tvis manifold and exhaust, valves with 3angle job polished, bigger cams 240?, springs etc. i buy it for 100eu as spare,
the guy has also gearbox from ae92
  Smallport coil totta Crolla 2 1,934 08-12-2022 11:03 AM
Last Post: totta Crolla
  Smallport inlet manifold totta Crolla 6 3,724 01-17-2022 05:14 PM
  Early tvis red top from e9 gti small or bigport? Ryo 3 7,792 04-20-2018 09:14 AM
  10.8:1, 264/256° Bigport nyberrg 4 6,647 06-12-2017 09:57 AM
Last Post: nyberrg
  4A-GTE 7-rib smallport nyberrg 5 6,598 05-24-2017 09:24 PM
Last Post: krullibull
