map sensor or something else?
09-19-2012, 10:02 AM
totta Crolla Wrote:The high idle when cold is perfectly normal. i know when she's cold that the idle should be high but didnt saw the video from 2000+rpms eg shes going suddenly to 1200rpms and then back to 2000rpms.... don t you see the unstable idle at hot? and she s (pop pop pop...) from behind the exhaust. dont you see on the afternoon video that the gas where is coming out of the exhaust is not stable? 4age 16v to FR 20VT |
09-19-2012, 12:50 PM
Ok the cold start.
When you crank the engine you are also injecting some extra fuel from a separate cold start injector hence the initial jump in revs. once this extra fuel is burnt (to help start the engine) the main injectors take over. Expect to see some instability in the idle until the engine is warm. (just like your video tbh) After reading your first post again and assuming the car was ok before the work was undertaken I would say that there is air in the cooling system and this is causing a problem with the water temperature sensor. Also you have a modified exhaust ? Modified inlet ? To get more air in and out of the engine ? You have no Oxygen sensor, correct ? The popping sound is probably because the engine is running lean at idle. This can be corrected however. Are you getting error codes from the ecu ? An analogue brain in a digital World |
09-19-2012, 01:51 PM
totta Crolla Wrote:Ok the cold start. my exhaust is modified is a stainless handmade and much more free than the stock one. Inlet is modified to (BMC Carbon dynamic box) No oxygen sensor correct (if is lean at idle how can be corrected?) a look at my exhaust system http://www.youtube.com/watch?v=AnKDAgCd4uY&feature=plcp No the last 3 days no errors on the ecu.... 4age 16v to FR 20VT |
09-19-2012, 04:25 PM
Here are the details:
http://www.jmrhzu.btinternet.co.uk/Old_C...rt4p1.html (you will need to find the actual adjuster screw on your car though and if your car did not have an Oxygen sensor from the factory it will have this adjuster BUT it may not look exactly the same as the photo) An analogue brain in a digital World |
09-19-2012, 05:26 PM
totta Crolla Wrote:Here are the details: Before a month ago i adjusted the co mixture at about 1.80% +- 0,5 4age 16v to FR 20VT |
09-19-2012, 08:04 PM
sorry for my greek guys but ΚΑΝΕ ΜΙΑ ΚΑΛΗ ΕΞΑΕΡΩΣΗ ΣΤΟ ΚΥΚΛΩΜΑ ΨΥΓΕΙΟΥ :wink:
AE86 FANATIC!!! |
09-20-2012, 07:04 AM
alimonos Wrote:sorry for my greek guys but ΚΑΝΕ ΜΙΑ ΚΑΛΗ ΕΞΑΕΡΩΣΗ ΣΤΟ ΚΥΚΛΩΜΑ ΨΥΓΕΙΟΥ :wink: sorry for my Greek too.Πόσο καλή δηλαδή;θα σου στείλω pm 4age 16v to FR 20VT |
09-21-2012, 07:53 AM
today morning http://youtu.be/5_fQvvVly2g
09-23-2012, 09:44 AM
i tried another throttle with another tps on and another air aux. valve.The same sh*t!I m tired....any help will be helpful
09-23-2012, 03:20 PM
Concentrate on the cooling system. It is the usual suspect for unstable idle RPM. Have seen it many times on many different 4age equiped toyota's.
Make sure there is no air in the system, take special notice of the pipes to the inlet manifold/throttle body. Sometimes they get clogged, and it is easy to imagine some air being trapped in the system since you had coolant lines replaced right before the problem occured. FABRICA MI DIEM, PVNC! |
Lambda sensor wiring | sam3007 | 10 | 4,239 |
AFM to Map Conversion | ps13michi | 3 | 3,094 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 10,881 |
extracted freedom ecu 16v ignition map | ditn | 7 | 8,750 |
Something of interest to all suspension number crunchers | Bean | 1 | 4,014 |
01-05-2015 10:29 AM Last Post: Uzelac |
