motor oil for 16V
11-06-2013, 05:01 AM
motor oil for 16V
I know this might have been discussed for many time but I still want to know more....
I searched the following info. for AW11:
http://www.bobistheoilguy.com/forums/ubb...er=2538703
And the "official" spec for motor oil is like:
[Image: AEU86 AE86 - motor oil for 16V]
Which mean, for the general temperature in my place, I should use 20W40 motor oil. This is fine, but I found that their is not many(or none) 20W40 motor oil for car, I could only find 20W40 motor oil for 4T motorcycle. I wonder if I motorcycle oil could be used on 4AG or not... Dumb question
11-06-2013, 06:11 AM
motor oil for 16V
kawo Wrote:I found that their is not many(or none) 20W40 motor oil
I don't believe you unless you're it's actually SF you're specifically looking for!!!!
That chart is at least 10 years old and SM (maybe SN?) is the current & best stuff you can get, SF is obsolete.
Read more on that site.
11-06-2013, 09:47 AM
motor oil for 16V
you should be able to find 10w-40 that is in the same temp range than the 20w40 but with better properties during cold.
That chart is now very old.
Do not use motorcycle oils, they have a slip agent because most motorcycles have their clutch lubricated by the engine oil ( unlike cars that run a dry clutch system)
11-13-2013, 07:30 PM
motor oil for 16V
if you want to use one of the best real synthetics and i mean 100% synthetics , you can use amsoil amo 10w40 is far the best oil ,according to amsoil tests and labs
4age 16v to FR 20VT
11-13-2013, 11:04 PM
motor oil for 16V
ehm.. amsoil tests conclude amsoil oil is the best? No surprise there..
11-14-2013, 06:00 PM
motor oil for 16V
Ivan141 Wrote:ehm.. amsoil tests conclude amsoil oil is the best? No surprise there..
amsoil has external labs that has the right to test oils......you can search for official test on web....and..see
4age 16v to FR 20VT
11-14-2013, 08:47 PM
motor oil for 16V
I live in a hot desert climate and have found that 10w-40 works good on both my 4age and 4afe engines. The oil itself is nothing fancy, just conventional Valvoline.
11-15-2013, 03:07 PM
motor oil for 16V
Oil discussions usually never end in any valuable conclusions.
My view on engine oil is simple: on any well used engine (100k+) I just throw in any oil I can get my hands on, cheap stuff bought from Lidl not excluded. Just make sure its the right specification (usually 10W40), and then make sure to do oil changes often enough (once every year).
Throwing expensive oil in an old engine will not make it a better engine, so why bother. If it burns oil, might as well top off with cheap stuff.
As far as tired 4age's are concerned I've had bad experiences with switching to thicker oil (15W40), if anything, my engines started consuming more oil after that.
On a freshly built engine I would consider full-synthetic for sure. Never had one though, so I havent had to bother to figure out which one to use... I'm sure there are plenty that are more than good enough for a simple old 4age.
11-15-2013, 10:31 PM
motor oil for 16V
Ivan nailed it ^^ Thumbs up!
11-15-2013, 11:31 PM
motor oil for 16V
Ivan141 Wrote:...make sure its the right specification (usually 10W40), and then make sure to do oil changes often enough... ...bad experiences with switching to thicker oil (15W40)...
PLEASE, you're going to scare someone!
I'm almost seriously sure that every kind of racing engine in the world has won using any&every major oil manufacturer/brand and grade possible at some time or another, except using gear oil in the engine the Siberian winter.
All have been accused of sludge, All have been accused of failures, when it's the owner or clearances or lack of lube or contamination as the real cause.
  trans oil, lsd oil change Apolan 9 17,644 10-01-2014 03:57 PM
  Starter Motor Help phill 92 3 6,123 11-25-2013 11:16 AM
Last Post: Apsogos
  Starter motor questions - rebuild Jezza_hr 6 8,399 08-31-2013 03:05 PM
Last Post: Apsogos
  How to fix a floating idle on a Toyota 4A-GE motor Homem Bomba 8 24,539 08-27-2013 12:55 AM
Last Post: jondee86
  How to adjust the idle speed on your Toyota 4A-GE motor Homem Bomba 1 4,686 06-30-2013 01:08 PM
Last Post: Homem Bomba
User(s) browsing this thread:
